Code For Running Ethernet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 01:29 PM   #1
Code for running ethernet
We have a few ethernet cables in the warehouse areas of my work that are just strapped to the building frame along the walls and ceiling. I know it isn't supposed to be run along with power lines. Does anyone know of any specific code that either says this is or is not OK? Management wants to know if this needs to go in conduit. Its been this way for a long time and I think it is OK, but I don't know of any code to support this. Thanks!
chris_b is offline   Reply With Quote
Old 03-05-2013, 01:54 PM   #2
Electrical Contractor
jbfan's Avatar
It does not need to be inside conduit.
We use a J hook to run the cables in.
jbfan is online now   Reply With Quote
Old 03-05-2013, 02:03 PM   #3
J hook as in a standard hardware hook?
Hardway is offline   Reply With Quote
Old 03-05-2013, 02:07 PM   #4
jbfan's Avatar
Sorry, no a J hook as in a caddy hook, or threaded rod we bent into a J hook.
Old 03-05-2013, 02:34 PM   #5
Thanks for the reply. I guess there is probably no code to cover the concept if no code is needed.
There are a million different varieties of J hooks so I assume whatever fits best is the right choice.
Here is an example:
http://deepsurplus.com/Network-Struc...k-Small-1-5-16
Old 03-05-2013, 02:47 PM   #6
jbfan's Avatar
Here is an example:
Right, whatever size you need to get the number of cables you have from point a to point b.
Old 03-05-2013, 04:16 PM   #7
Rewards Points: 166
You still might want to consider physical protection of the cables. If they are stapled to exposed framing in a warehouse then they are susceptible to damage. One bump by the edge of a pallet or other hard object is all it takes sometimes. Ethernet cables contain several very small wires that are easily damaged and if you have a bundle of them it can be a royal pain to locate the source of any problems.
dftc is offline   Reply With Quote
Old 03-05-2013, 04:58 PM   #8
All of the cables right now are high up on the walls and fastened with zip tie like straps that are attached to the concrete walls or metal beams. We don't stack anything higher than 2 pallets high so they are above that.
Thanks.
Old 03-05-2013, 05:15 PM   #9
Rewards Points: 6,652
Having a heavy gauge sheet metal cover made to protect the cables would be the best thing. Most times if the cables are in an area that they can be damaged, they will be ran in a couple of steel EMT to protect, or in a cable tray. Especially if there is fiber involved.
Old 03-06-2013, 08:50 AM   #10
Rewards Points: 313
If they are not subject to damage, I wouldn't touch em. Tie raps will last a long time if they are the black ones (UV protection). I've seen LV cables strung like spaghetti in warehouses and high bay. Doesn't look very professional, but it works for them.
al_smelter is offline   Reply With Quote
Old 03-06-2013, 11:31 AM   #11
Licensed electrician
Rewards Points: 1,266
Tie wraps that are too tight can damage the cables.
Old 03-06-2013, 01:45 PM   #12
Rewards Points: 313
You'd have to tighten them pretty well, but yes, they are tiny conductors and could be damaged. However, the OP states that these cables are already in service and in good shape. I still would let sleeping dogs lie if the cables are out of harms way and they aren't simply looking to pretty the place up.
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 08:24 AM
Plumb island sink and AAV code for Ajax jhakkim Plumbing 2 02-14-2012 12:07 AM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 11:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 02:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 07:14 PM
