Code For Retrofit? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-03-2009, 09:50 PM   #1
Knucklez's Avatar
Rewards Points: 932
code for retrofit?
ok, this has been bothering me for a while. is there, or is there not, a special code section for retrofit work (in canada)?
for example, stapling electrical wire to studs.. during a retrofit, you may not have the walls open, so you can't really staple..
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 11-03-2009, 10:01 PM   #2
joed's Avatar
Rewards Points: 12,440
You must follow current codes for retrofit. You are not required to open walls to staple wires. They can be left floating inside the wall. Other codes like cable size, dedicated circuits, location and outlet count etc. must be followed.
Old 11-06-2009, 07:09 PM   #3
Knucklez's Avatar
Rewards Points: 932
ya, that's what i thought about the stapling. but i could never confirm that with actual code reference. seems its always about new installation.
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Carrier 9200 Code 34 fault cu1982 HVAC 8 01-02-2009 08:56 PM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 09:43 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
