Code Requirements For Remodel Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 11:40 PM   #1
Green Hat
Rewards Points: 170
Code requirements for remodel wiring?
Gents, just wondering if anyone has ever had any experience with codes in TN that regards remodel wiring?
I am adding a few outlets on an outside wall of a room in my basement, and wall sconces on the back wall. I can run the wiring through the top plates in the framing and into a remodel box, however the wiring will not be stapled to the framing on the inside of the walls. I am guessing that this is the only way to do this, and I dont feel like removing the sheetrock in order to tackle the project.
Anything wrong with this in regards to safety or code violations?
Thanks!
Mills314 is offline   Reply With Quote
Old 01-15-2012, 01:10 AM   #2
Julius793's Avatar
Thanks!
Is this your question?
is not stapling wires when fishing them through a sheetrocked wall ok? If that's the question the answer is, it's fine.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-15-2012, 08:25 PM   #3
Green Hat
Rewards Points: 170
That pretty much summed it up.
Just wanted to give the full run down to avoid confusion.
Thanks.
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 06:13 PM
Code requirements for outlet placement WillK Electrical 8 11-30-2010 08:16 PM
Code for Outdoor fan wiring EEPE Electrical 2 07-26-2010 06:49 PM
Question about AFCI and Ontario code as well as some other general wiring queries drunken0monkey Electrical 5 06-15-2010 09:49 AM
What's code for wiring distance from end of studs? Webguy64 Electrical 2 07-17-2007 05:58 AM
