Code Requirement On Conduit Going Through Roof That Main Feeder Wires Come Through - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 10:20 PM   #1
code requirement on conduit going through roof that main feeder wires come through
What is the height requirement on conduit coming through roof? What do I do if main feeder wires are not long enough.
rebelbull is offline   Reply With Quote
Old 01-27-2012, 10:37 PM   #2
Licensed electrician
Rewards Points: 1,054
What is the slope of the roof? You can check NEC Article 225.18.
If the conductors are not long enough you would install new ones.
plummen (01-28-2012)
Old 01-27-2012, 10:39 PM   #3
I would have to install new ones or poco
Old 01-27-2012, 10:44 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
Usually the poco owns to the point of attachment, so the wire in the conduit belongs to you.
Old 01-27-2012, 11:01 PM   #5
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would also check with the power company for height requirements because they may have certain requirements.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
Old 01-28-2012, 03:32 AM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is this on a house or building?
Is it coming from across a yard or driveway?
Do you get a lot of snow in your area?
plummen is offline   Reply With Quote
Old 01-28-2012, 07:03 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
This is an odd question. What's the relevance?
Speedy Petey is online now   Reply With Quote
Old 01-28-2012, 07:05 AM   #8
There is not nearly enough info here to provide an accurate answer.
The height through the roof of the service mast is typically 3'.
Why would the service conductor not be long enough? Are you replacing the mast?
Old 01-28-2012, 07:28 AM   #9
plummen's Avatar
Very simple if youre in an area that tends to have 2' of snow sitting on your roof for a couple weeks at a time you might want to take that into consideration
Old 01-28-2012, 07:35 AM   #10
The code does not change the height requirement based on snow. My utility also has a height limit so the weatherhead can be reached with a ladder.
Speedy Petey (01-28-2012)
Old 01-28-2012, 07:36 AM   #11
plummen's Avatar
Most of our service masts in this area are not over 24".
I had an inspector ask me why I had a service mast coming 4' out the roof of a residential garage that butted up to an alley in south omaha years ago.
I just pointed to the semi-truck repair shop next door that used the same alley as an alternate entrance to their shop,and the pole being directly across the alley from garage.
I told him the first time they brought a truck/trailer in through there to be worked on hed know why I had that service set so high to clear that alley!
Of course I had to support the 2" rigid pipe in 2 directions to make him happy
Old 01-28-2012, 07:39 AM   #12
plummen's Avatar
No but common sense should play into things shouldnt it?
Old 01-28-2012, 07:41 AM   #13
WHY? Do you go walking around on your roof with 2' of snow on it?
Old 01-28-2012, 07:42 AM   #14
Bottom line is it needs to be as high as necessary to get the required service drop clearance over whatever terrain it hangs over.
Typically the mast is 3' high, with the POA at 24" above the roof.
Any higher would require a back guy in most areas.
Old 01-28-2012, 07:44 AM   #15
You don't shovel your roof?
Secure Wires from Conduit in Sub Panel brgmgb Electrical 7 09-29-2011 10:10 PM
Is it legal to run wires on the ground, in conduit? Red Squirrel Electrical 20 02-22-2011 03:59 PM
Michigan code regarding roof over stuwithau Roofing/Siding 8 07-21-2009 02:14 PM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 06:57 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
