Code Ref. Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 08:22 PM   #1
ericmunyon12345's Avatar
Code ref. question
Hey,
I'm hunting around to find the nec code that says something dealing with simplex receps on dedicated circuits and what they can serve. Any help?
Also, does the newest code remove the gfci exception for freezers, sump pumps, etc. in a basement?
ericmunyon12345 is offline   Reply With Quote
Old 03-04-2013, 08:40 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by ericmunyon12345 View Post
Hey,
210.21 (B)(1)
GFCI protection is required.
Old 03-04-2013, 08:48 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,942
You are correct on the GFCI exception change, but I think it was two code cycles ago. What is your question about dedicated single receptacles? You can use them for whatever you want, unless there's some other code provision that would affect your application.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Electrical panel code question rap4rent Electrical 10 12-18-2012 07:49 AM
Code question - Romex in garage billman5000 Electrical 11 11-29-2012 05:58 PM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 05:34 PM
I have one code question which needs to verify. David200888 Electrical 0 12-21-2010 09:21 AM
question about code chrissy2008 Electrical 14 02-01-2009 09:48 PM
