Code Question - Subpanel For Second Floor - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 12:51 AM   #1
Code question - subpanel for second floor
Hi again,
So I'm looking at my second floor remodel plans, and I'm thinking it will actually end up being a lot easier if I just wire my second floor with a 60A subpanel rather than running individual wires for all the circuits up from the basement.
I'd run a 6/3 cable from the basement main panel up to a subpanel on the second floor, and then branch all the second floor's circuits (bedroom, hall, bathroom) off of there. The only "separate" circuit wire that would be coming up is for the smoke detectors, which obviously have to be tied in to all the other ones around the house.
My question is, are there any code requirements with respect to how this is done?
Specifically:
1. The subpanel will easily fit into the wall framing, between two studs. Can I just put it there then drywall around it as long as it obviously is still fully accessible?
2. Any location requirements? I have a little "alcove" at the end of my hall which used to be a small walk-in closet but I am going to de-frame it and just have it be part of the hall - it'd also be a perfect place for the subpanel based on how the wire run will be coming up from the basement and also wiring runs to the rest of the floor. OK?
3. Is it allowed to build out a little wooden cover over the spot where the panel is, just for aesthetic's sake? Was thinking I could build a lightweight wooden door in a little frame and mount it over the panel, thus leaving easy access to get inside and work the breakers or even open the panel, but can be closed to make the area look nice.
Thanks again!
F
fdmillion is offline   Reply With Quote
Old 01-22-2013, 03:36 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
AS long as its accessable you should be fine,remember to separate neutral/ground conductors in the sub panel
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-22-2013, 05:13 AM   #3
Licensed electrician
Rewards Points: 1,020
Do you have space for a refrigerator sized box in front of the panel? If you do you can probably locate your panel there.
Old 01-26-2013, 11:18 PM   #4
Thanks for the advice. I'm going to run the 6/3 straight up from the basement directly upwards to where the panel will be. This makes the cable run the easiest. It will end up being in a sort of "open" area - on the wall in the hall - but if I cover it with a wood "door" like I said it'll end up looking attractive and still be accessible when needed.
F
Garage Subpanel Wiring Question Joe85 Electrical 10 03-06-2011 04:14 PM
Rafter framing code question anesthes Building & Construction 32 01-21-2011 11:43 PM
Woohoo ... got the new bamboo floor installed ... baseboard question Stephen S. Flooring 7 06-22-2010 06:34 PM
subpanel feeder question ssybert Electrical 4 01-28-2010 10:29 AM
Tiling over a "Gooey" floor question Gusaroo Flooring 7 09-08-2008 09:27 AM
