#1 |
Code question - Romex in garage
Hi, got a typical homeowner situation ->
1) Is the use of Romex in the two pictures, permitted under the electrical code ? 2) From what I've read this is not up to code, so - could I replace it with armored cable ? "MC", or what is commonly and incorrectly called "BX". Thanks ! |
#2 | |
E2 Electrician
Code question - Romex in garageQuote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Lic Electrical Inspector
What year NEC was it wired/inspected under? The receptacles in garages may need GFI protection depending on when it was wired and location. Where do you live?
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#4 |
electures: The house is in Indiana, it was built in 1950, and I bought it a few years ago. The wire in the pictures was probably done in the last decade or so. I never thought about it until today.
#5 |
Until recently romex was not permitted in a detached garage. SO it appears that at the time the wiring was installed it may have been a violation if the garage is detached. Under the 2011 NEC romex is permitted in a detached garage. If the garage is attached to the dwelling then the point is mute. However, GFI protection of receptacles in a garage is required barring local amendments.
#6 |
Average Joe/ex-Navy IC3
The Romex, I would protect in the Romex going down the wall in Conduit. Unless your local AHJ states otherwise, and the work is in good workmanship and code compliant, get on to the next project.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#7 |
Garage is attached. Thank you for the info !
#8 | |
#9 |
IIRC nothing in the garage has GFI....I wlil add that to the list.
#10 |
When you replace the outlet with the GFCI, get a smaller coverplate that fits your box. The corners of those plastic plates extending beyond the box are a hazard. (Tears clothes or skin)
I might even go to the trouble of rounding down the corners of the existing plate, until I got around to getting to the GFCI, Last edited by Oso954; 11-29-2012 at 04:57 PM. |
#11 |
Residential Designer
Wow, interesting. Here in CA. if the inspector saw either of those two situations he might try to have me drawn and quartered, then have my bollocks cut off.
In the first picture, unless the Romex was above 8 feet high it would have to be MC cable. The Romex in the second picture would surely get me a failure in inspection. Would need to be in conduit or armored cable. Andy.
Residential Drafter/Designer To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#12 | |
Licensed Electrician
Not a fan of the new layout.
Answers based on the National Electric Code. Always check local amendments. |
| Tags |
electrical code ![]() |
| Display Modes | |
| Expanding Garage INTO house (goodbye Den) | texaopian | Building & Construction | 16 | 11-07-2011 11:32 PM |
| Garage insulation question | silverfox103 | Insulation | 0 | 10-05-2011 10:10 AM |
| Rewiring the house, garage subpanel question | WillK | Electrical | 4 | 09-28-2010 11:14 PM |
| Question about insulating a garage forCcanadian winters | trucker | Building & Construction | 3 | 02-08-2008 06:07 AM |
