Code Question, Elec. Water Heaters - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2009, 10:12 PM   #1
Code question, elec. water heaters
A WH is on #14, which is undersized for a 4500w, 240v element.
If the element is changed to 3300w or lesser wattage is there any reason that the 15A breaker feeding the #14 wire cannot stay?
I realize the recovery time will be longer.
Old 11-14-2009, 10:30 PM   #2
15a is only good for 1800w
If its 3300w combined between 2 heaters - each 1650w then I'd think so
A 4500w (37.5a) heater actually has 2 heaters = both are 4500w
Only one works at a time
Mine is on a 30a breaker & #10 wire (I think - have to check)
Yup....30a 240v breaker
And that is what was called for in the installation instructions
Old 11-14-2009, 10:36 PM   #3
15A is 3600 watts at 240V.
jerryh3 is offline   Reply With Quote
Old 11-14-2009, 10:40 PM   #4
Thank you....must be tired
That's why 30a 240v works for mine
Old 11-14-2009, 10:46 PM   #5
Yep. It's late. If you could get the WH down to 2880 watts, I guess you could use a 15A. But, 110.3(b) may work against you.
Old 11-14-2009, 11:02 PM   #6
Thanks, I'll look it up.
Old 11-15-2009, 03:42 PM   #7
Electrical Contractor
kbsparky's Avatar
We changed the incoming voltage to 120 when we encountered a similar setup a few years ago. It was impractical to change out the wiring.
That meant the water heater operated at 1125 watts. If starting from a dead cold tank, it would take 8 hours to heat the whole thing. AFAIK, there never was any complaint about not having enough hot water ....
-KB
Old 11-15-2009, 05:44 PM   #8
Idiot Emeritus
Rewards Points: 1,492
I've fed a 4500 watt 240 volt water heater with 120 as well. Like KB stated, it's a bit slow, but it does work.
#14 is OK this way, the actual current is about 10 amps.
I'm sure this violates hundreds of codes, but here's the bottom line; it works, and there's absolutely zero compromise of safety.
Rob
micromind is offline   Reply With Quote
Old 11-15-2009, 06:24 PM   #9
Thanks, folks. . .
Old 11-15-2009, 09:09 PM   #10
Thumbs up
Using the formula I=P/E you arrive at a usage of 13.75a.; Even if it's considered a continuous load, you'll arrive @ 13.99a.; You should be OK with a 15a. breaker or Cartridge Fuse; But I would still use a #12 wire if it's not too much trouble to rewire. (No matter what) Don't drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-15-2009, 09:40 PM   #11
It IS considered a continuous load, and 3300w load would require a branch-circuit rated at 17.1A. For the 14AWG circuit, the limit is 2880w as jerry said.
Willis
williswires is offline   Reply With Quote
Whole house water filter question Davidb6 Plumbing 4 07-01-2009 10:36 PM
2 water heaters - saving energy rjamesh Plumbing 16 10-18-2008 11:33 AM
Are tankless water heaters a good choice for the midwest darkman32 Plumbing 27 10-14-2008 06:36 AM
I have 2 water heaters and have a question wackerjr Plumbing 22 01-22-2008 07:00 PM
water hammer question seanstoner Plumbing 7 04-10-2006 05:28 PM
