Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 09:12 AM   #1
Code question
Does code allow for an outlet between a pantry door and garage door on a 1 1/2 to 2 foot section of wall?
redrumliny is offline   Reply With Quote
Old 09-04-2009, 09:19 AM   #2
Rewards Points: 2,350
Yes
Old 09-04-2009, 09:24 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
If the wall in question is part of the kitchen, it would have to be on one of the kitchen counter circuits, would it not?
Kyle
Old 09-04-2009, 09:44 AM   #4
The pantry is the end of the kitchen area, the garage door is in an alcove area, and that section of wall is in the transition between. It will be on the circuit that the fridge is on.
Old 09-04-2009, 09:54 AM   #5
Remodeler
adpanko's Avatar
Rewards Points: 150
Yes, you can definitely put an outlet there. There is nothing in the code that would prevent placing an outlet in what seems like and ordinary run of wall. (the width of the wall or the room that it is in doesn't come in to play in any unique way in your situation). The only thing I'm not sure about is putting that outlet on the fridge circuit. Someone please correct me if I'm wrong, but doesn't each stationary appliance need its own circuit? Practically speaking, a fridge doesn't use too much power, so you can most likely run that outlet off of it and never trip the circuit (depending on the amperage of the circuit, what else you might already have on there and what you plan on using on that outlet).
adpanko is offline   Reply With Quote
Old 09-04-2009, 10:03 AM   #6
Probably a wall mount phone that will require a 110 outlet and maybe a small pantry light
Old 09-04-2009, 10:14 AM   #7
A fridge & stationary (not fixed in place-is that what you mean) appliances do not need dedicated circuits
There are exceptions such as some items fixed in place, & special rules for other items
Built in microwave
Built in fan/hood combo
Dishwasher
Garbage disposal
I prefer a fridge on a dedicated circuit
Old 09-04-2009, 10:37 AM   #8
Licensed electrician
Rewards Points: 1,622
Unless the instructions for the fridge called for a dedicated circuit it can share. Subzeros call for a dedicated circuit at least with some of their models.
Old 09-04-2009, 11:24 AM   #9
Thanks Gentlemen!
Old 09-04-2009, 11:59 AM   #10
Remodeler
adpanko's Avatar
Rewards Points: 150
FYI: I went over the top with adding circuits when I redid my kitchen two years ago. I didn't want to find out after the inspection that I needed to run more dedicated circuits, so I put every appliance on its own (except for doubling up on the garbage disposal and insta-hot tank under the sink) 9 circuits in total.
20A - countertop outlets (1)
20A - countertop outlets (2)
15A - refrigerator
15A - range hood/light
50A - oven
20A - built-in microwave
20A - garbage disposal & insta-hot water tank
15A - dishwasher
15A - ceiling and undercabinet lights
But anyway, if you are only going to put a phone and a light on the circuit with the fridge, I don't see that being a problem or an inspector not allowing it.
Old 09-04-2009, 12:51 PM   #11
300zx's Avatar
15A - refrigerator
50A - oven
15A - dishwasher
Refrigerator on 15 amp ? I would have put on 20 amp breaker with 12-2,But thats just my opinion.
300zx is offline   Reply With Quote
Old 09-04-2009, 12:54 PM   #12
I ran 12-2 for my refridge & had a 15a so installed that breaker
I'll have 4 kitchen counter circuits when I'm finished, plus a 5th in the adjoining sunroom
I've learned you can never have too many circuits for the kitchen
Old 09-04-2009, 01:57 PM   #13
Remodeler
adpanko's Avatar
Rewards Points: 150
I don't recall the exact wattage, but when I checked the the spec sticker, it was far below the 1,650 total available wattage of a 15A circuit, so I went with 15. It is not one of those monster 48" wide Sub Zeros or anything, just a basic looking 21 cu ft GE Profile. I assume larger units may need 20A.
Old 09-04-2009, 02:45 PM   #14
Mine's a 26 cu ft & still specified a 15 a circuit (1800 watts available)
Old 09-04-2009, 02:58 PM   #15
Electrical Contractor
kbsparky's Avatar
Section 210.52(B)(1) Exception No. 2: The receptacle outlet for refrigeration equipment shall be permitted to be supplied from an individual branch circuit rated 15 amperes or greater.
-KB
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
Nordyne Furnace G6TL Question # 2 kentcasey HVAC 1 01-28-2009 10:11 PM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
wire junction code question wfischer Electrical 9 03-01-2008 09:21 AM
Conduit, above ground, code question davewest Electrical 6 02-27-2008 03:55 PM
