Old 11-28-2011, 01:16 PM   #1
Code question
Im wiring up an addition I just did and need to know about lighting and outlets circuits.
2 bedrooms
1 hallway
Recessed lights in those 3 areas
What has to be arc fault or gfci?
Thx!
serrano is offline   Reply With Quote
Old 11-28-2011, 01:44 PM   #2
Code question
Depends on code where you live. In some places (like where I live), AFCIs are required only for bedroom circuits. In others following a newer version of the code, they are required in every occupied area of the house. You should check with your local building department.
Old 11-28-2011, 06:36 PM   #3
joed's Avatar
Code question
Since you didn't post a location I will give you the Canadian version.
In Canada only the bedroom receptacles need to be AFCI. The smokes must NOT be AFCI. Nothing listed needs to be GFCI.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-28-2011, 07:01 PM   #4
Code question
Sorry, Los Angeles Ca
Does the lighting need anything?
Old 11-28-2011, 07:33 PM   #5
Code question
It depends upon what code revision you are on. The LA County website says it is based upon the 2010 California and 2008 National Electric Codes.
In 2008 NEC requires AFCI breakers in:
"210.12(b) Dwelling Units. All 120-volt, single-phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sun rooms, recreation rooms, closets, hallways, or similar rooms or areas shall be protected by a listed arc-fault circuit interrupter, combination-type, installed to provide protection of the branch circuit."
So, it looks like they all need to be AFCI, but check with your local AHJ.
Yes, it includes the lighting.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
ben's plumbing (11-28-2011)
Old 11-28-2011, 08:23 PM   #6
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Code question
AFCI on all, I am suspicious of Dan's contention of the requirement on the lighting circuits. I will check this out to be sure. Lights are not outlets.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Old 11-28-2011, 08:38 PM   #7
Code question
Yes the lights, and even the smoke detectors, need to be AFCI protected, 2008 NEC.
Check out the definition of an "outlet."
Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
It may vary where you live.
Old 11-28-2011, 08:55 PM   #8
AndyGump's Avatar
Code question
So a light fixture is utilization equipment?
Andy.
Old 11-28-2011, 09:07 PM   #9
Code question
Yes. It is if you want light.
The NEC would have stated "receptacles" if they meant anything else.
Old 11-29-2011, 09:57 AM   #10
Electrician
SD515's Avatar
Code question
Correct. A receptacle is a receptacle (more specifically, a device), an outlet is an outlet. They are not the same, though it’s been common for many years to call a receptacle an outlet. One of those situations where you have to clarify what someone is saying versus what they are meaning.
Kyle
Old 11-29-2011, 10:00 AM   #11
Licensed electrician
Code question
A smoke detector also qualifies as an outlet under the NEC defintions that has already been provided above.
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 06:34 PM
Stairway wall help.. (Code question) casper129 Building & Construction 6 07-21-2011 05:24 PM
I have one code question which needs to verify. David200888 Electrical 0 12-21-2010 10:21 AM
Question about exposed junction box on floor & code BradG Electrical 9 03-21-2009 12:05 PM
question about code chrissy2008 Electrical 14 02-01-2009 10:48 PM
