Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 12:45 PM   #1
Rewards Points: 20
code question
I recently purchased a home built in 2008 and I am in the process of finishing off the basement. Stud walls are up and I am ready for putting in furnace/air vents and electrical. The Realtor who sold me the home (same company as the builder, conveniently) mentioned something about needing to have an outlet every 8 feet (not sure about the 8, but it was every "so many" feet) along the walls of each room when we discussed finishing the basement.
I just checked the NEC 2008 and see nothing about this. I could be missing it since it is like 800+ pages though, or it could be a 2011 thing. Iowa and my county both use the 2008 code, so I wanted to check here to see if anyone had heard of this.
I don't think it is going to be a problem since I like having accessible outlets and will likely put in more than would be required, but I want to be sure.
Thanks for any help offered.
duhtroll is offline   Reply With Quote
Old 07-13-2011, 01:07 PM   #2
Master Electrician
Rewards Points: 3,916
http://www.ashireporter.org/articles...s.aspx?id=1805
NEC 2008 210.50
brric is online now   Reply With Quote
Old 07-13-2011, 01:07 PM   #3
Mad Scientist
Since you've got a copy of the NEC, look at 210.52, I believe. Basically:
No point along the wall can be more than 6' from an receptacle, therefore receptacles should be no further than 12' from each other. Any wall space wider than 24" requires a receptacle.
McSteve is offline   Reply With Quote
Old 07-13-2011, 01:21 PM   #4
Rewards Points: 20
Got it - thanks - knew I was probably looking in the wrong chapter.
3" Remodel Recessed Lighting Question - Code easelpad Electrical 2 01-07-2011 08:29 AM
I have one code question which needs to verify. David200888 Electrical 0 12-21-2010 09:21 AM
Question about exposed junction box on floor & code BradG Electrical 9 03-21-2009 11:05 AM
question about code chrissy2008 Electrical 14 02-01-2009 09:48 PM
wire junction code question wfischer Electrical 9 03-01-2008 09:21 AM
