Is This To Code... Puerto Rican Hot Water - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 06:26 PM   #1
Learning by Doing
Leah Frances's Avatar
Is this to code... Puerto Rican hot water
Well, it looks pretty snazzy..... I'm pretty sure I'll be taking cold showers
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-31-2011, 06:36 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
I think we had some guy from Miami looking to install one of those in a rental he was in.
I bet they are like that everywhere down there.
Enjoying the trip?
Old 03-31-2011, 06:42 PM   #3
Learning by Doing
It's the first one we've seen, though I've seen the 'shower' outlets a few times. On our way home with a lot of good memories, as much good rum as we can carry and a good sunburn.
We saw the entire island (each corner and drove the Ruta Panoramica through the middle).
Arecibo Observatory was SUPER COOL. DH loved all the snorkeling.
Old 03-31-2011, 07:35 PM   #4
Rewards Points: 6,652
They call them Suicide showers for a reason.
Old 03-31-2011, 07:51 PM   #5
Old School
Willie T's Avatar
Here's a more advanced one from Guatemala.
Willie T
Old 03-31-2011, 09:18 PM   #6
Rewards Points: 1,016
I have seen varations of the same throughout Asia. Scary...
Old 03-31-2011, 09:42 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
It might be to their code. It isn't NEC compliant but unless they use the NEC, that is irrelevant.
I like the one from guatamala with what looks like a metal switchbox and cover.
Old 03-31-2011, 10:06 PM   #8
Rewards Points: 1,536
It does have a 3 prong plug and is connected to a grounded receptacle, no?
And a GFCI protected power feed would help.
Old 03-31-2011, 10:10 PM   #9
Experienced
Jackofall1's Avatar
The only thing missing on that recepticle is the shower cap
Mark
Old 03-31-2011, 10:48 PM   #10
Old School
Willie T's Avatar
Can you even buy two prong receptacles anymore?
Willie T
Old 04-01-2011, 01:00 AM   #11
" Euro " electrician
frenchelectrican's Avatar
I have see them a bit in European area and we do have very specfic codes to follow for the shower head water heater.
They have to be on mantory RCD { GFCI } and it will be typically hardwired no cord / plug attachement allowed.
We do have plastique junction box for this purpose when we get done termated them up we put a sealeant inside the box { I know few will have to do that and others will use gasket to seal up the box (that I never trust 100 % of time )}
In USA IIRC they must be on GFCI no extempts on it for other items I will have to look it up due not super wide spread and only found in few areas.
And most shower head heater typically will have between 3 to 5 KW { European verison }
Merci.
Marc
Old 04-01-2011, 05:38 AM   #12
That should have an in-use "bubble" cover....ya never know....water could splash up there!
The one from Guatemala is just scary...makes me wonder what the rest of the house looks like.
The whole thing must be one big code violation!
Do It Right is offline   Reply With Quote
Old 04-01-2011, 06:12 AM   #13
they dont show the pump handle for priming the shower
The older I get the better I was
Old 04-01-2011, 07:00 AM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Sure can, Home Depot and any electrical supply house carries them. They are only for replacement of existing non-grounded receptacles.
Coastal South Carolina
Old 04-01-2011, 10:51 AM   #15
Learning by Doing
Merci.
Marc
Merci, Marc. I thought it might be, because in general things seem to be built to a higher standard here than in other places in the Caribbean. It is a US protectorate.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Does code require floor drain for water heater? Quickdraw Plumbing 1 05-21-2009 06:29 AM
