Code For Outlet Placement In Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2008, 10:45 PM   #1
Code for Outlet Placement in Basement
Is there a minimum height requirement for outlets in a basement? In other words, can they be installed along the baseboard or do they have to be a certain height above the slab?
redbandit is offline   Reply With Quote
Old 01-01-2008, 11:44 PM   #2
Union HVAC Tech.
Any height you like.
bigMikeB is offline   Reply With Quote
Old 01-02-2008, 12:17 AM   #3
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Above fema flood level, but if you have a basement thats probably not an issue
Kingfisher is offline   Reply With Quote
Old 01-02-2008, 01:45 AM   #4
Thanks for the replies!
FEMA flood level? Is that the same specification as the flood plain or is that a more stringent specification? I know that the house and basement are not in a flood plain.
Old 01-02-2008, 07:09 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
If this will be a habitable room, the "required" receptacles cannot be more than 5'6" off the floor. Aside from that do anything you want.
Old 01-02-2008, 11:13 AM   #6
Thanks bigmike, kingfisher, and speedy, those were the answers I wanted to hear.
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
Finishing basement - electrical code ??? normwannabe Electrical 1 01-23-2006 08:48 PM
