Code for Outlet Placement in Basement
Is there a minimum height requirement for outlets in a basement? In other words, can they be installed along the baseboard or do they have to be a certain height above the slab?
Any height you like.
Above fema flood level, but if you have a basement thats probably not an issue
Thanks for the replies!
FEMA flood level? Is that the same specification as the flood plain or is that a more stringent specification? I know that the house and basement are not in a flood plain. |
If this will be a habitable room, the "required" receptacles cannot be more than 5'6" off the floor. Aside from that do anything you want.
Thanks bigmike, kingfisher, and speedy, those were the answers I wanted to hear.:thumbup:
| All times are GMT -4. The time now is 01:56 PM. |
