Code & Nail Plate & Wire On Face - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 08:12 PM   #1
Code & Nail Plate & Wire on Face
Builder decided to run wire the shortest route possible. So now when finishing a basement I can either rewire or Im wondering if nail plates will be accepted. Below are two photos of two areas that are in question. The third photo is what Im thinking is the fix. Would the fix be accepted?
Code & Nail Plate & Wire on Face-wire-1.jpg   Code & Nail Plate & Wire on Face-wire-2.jpg   Code & Nail Plate & Wire on Face-wire-protection.jpg
casnj is offline   Reply With Quote
Old 03-19-2012, 08:17 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Nail plates will not help here.
You are going to have to reroute those wires.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
gregzoll (03-20-2012), Julius793 (03-19-2012)
Old 03-20-2012, 12:37 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
That looks like a lvl beam....
This is a link that shows where you can drill holes
http://homeremodelersstore.com/web_a...ling%20lam.pdf
ddawg16 is online now   Reply With Quote
Old 03-20-2012, 12:56 AM   #4
Rewards Points: 14,014
Why is there what looks like untreated 4 X 4's that do not even make contact with the LVL's.
Old 03-20-2012, 07:10 AM   #5
Rewards Points: 6,652
Those are actually 2x2. I would like to see some more pictures of this improper build.
Old 03-20-2012, 08:39 AM   #6
Licensed Pro
Either reroute the wires or frame around them so proper clearances are maintained.
Old 03-20-2012, 09:03 AM   #7
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Are those wires wedged between that beam and the twigs holding it up?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-20-2012, 09:28 AM   #8
Licensed Pro
It appears the beam is resting on the 2x4 wall and that the 2x2's are being used as furring strips and bear no load. Slipping the wires in that gap will not be a problem IF proper measures are taken to protect the wire.
Old 03-20-2012, 09:48 AM   #9
rrolleston's Avatar
This is one of those things where you have two large structural beams and it's too hard to tell from a picture the best way to route or drill. I have never seen an installer do something quite like that with wire routing. I would check out ddawg16's document and make sure it applies to what you have and make sure you measure many times before doing anything.
How high is the beam and how high are you looking for in a finished ceiling?
Old 03-20-2012, 04:11 PM   #10
Just a DIY guy
If the beam is high enough, you could attach another 2x2 (or 2x4) to the BOTTOM of the LVL to use as a drywall nailer. If you attach the ceiling to the bottom of that attached 2x2, it would bring your drywall and ceiling below those wires. (assuming it's OK to attach wood to the bottom of the LVL)
Not sure if that's code compliant, and not sure if that would adequately protect those wires without plates, etc.
Might be faster and easier to reroute.
M3 Pete is offline   Reply With Quote
Old 03-21-2012, 01:56 PM   #11
to answer the questions. it is properly framed. the 2x2 are there to fur out the wall so I can run the wires thru a 2x2 with a nail protection plate. being that I cant drill thru the 2x4 as the lvl rest on it.
Router Mortising Kit for Door Face Plate GeauxCajuns82 Carpentry 9 02-15-2011 11:08 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
conduit for infloor heating (from floor / plate up to t-stat box) rtoni Electrical 8 12-09-2010 12:25 AM
wood framing-screws or nails? ron0805 Carpentry 8 10-15-2009 10:20 PM
Getting shocked by face plate screws vogtage83 Electrical 21 12-04-2007 11:55 AM
