Code Method To Splice UF Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2006, 08:46 PM   #1
Code method to splice UF wire
I need to extend two buried UF type wires in my yard. I assumed I would need to use a surface accessible, waterproof junction box and wire nuts to make the splice. The local Lowes store sells a device made of copper with set screws and a heat shrinkable sleeve that accoding to the package can be buried.
I needed to move my shed because it was on the property line and it was set too low so it flooded. There are two seperate UF type wires run to the shed to provide power for the sprinkler submersible pump and the power in the shed.
The cables are both about seven feet short because of the shed movement and I prefer to splice them in some manner instead of digging a trench across the yard and installing new wire.
What does the NEC allow or require for splices on UF type wire?
dleger is offline   Reply With Quote
Old 02-27-2006, 06:12 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I am not a pro electrican, so I can't speak to code requirements, but there are several ways to connect UF underground.
All that I've seen usually involve some type of built-in silicone sealant inside the device or wirenuts made for the purpose.
Shop around. I use those special wirenuts made for the purpose, and wrap them heavily in electrical tape for my underground boathouse wiring connections. Works for me.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-27-2006, 08:27 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
While the slilcone wire nuts will work, alone they are quite illegal.
This is one of the only legal ways to splice UF underground:
3M UF slice kit
Speedy Petey is online now   Reply With Quote
Old 02-27-2006, 12:30 PM   #4
Been around the block
I agree with speedy get an underground splice kit and do it the right way. Im a little sick and tired of people thinking electrical tape is the miracle cure for everything.
eleservtech is offline   Reply With Quote
Old 02-27-2006, 07:38 PM   #5
Home Improvement Guy
ron schenker's Avatar
Ya, I'm with Etech regarding black electrical tape. Isn't hockey stick tape way better lol.
ron schenker is offline   Reply With Quote
I really need help! POOK Electrical 34 04-20-2007 07:01 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
