Code History -- Reduced Size Ground Conductors Okay - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 07:03 PM   #1
Rewards Points: 93
Code History -- Reduced size ground conductors okay
I know that currently grounding conductors in NM cables (Romex) need to be the same size as the current carrying conductors. I also have seen older wiring where the ground is sized smaller. This was common in the 1960's. Does anyone know when the code was changed?
Perry401 is offline   Reply With Quote
Old 05-08-2011, 04:14 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Perry401 View Post
I know that currentlly grounding conductors in NM cables (Romex) need to be the same size as the current carrying conductors. I also have seen older wiring where the ground is sized smaller. This was common in the 1960's. Does anyone know when the code was changed?
I think it was in 1973 or little before that I may check with one guy he know the history on that so I may ask him for backtrack a littel to see how far it was but IIRC it was about the same time the older Alum branch conductors were no longer legit { old #12 , #10 AWG AL only }
Merci,
Marc
Old 05-08-2011, 04:43 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,180
In 1977 I was building a cottage in western Mass. NM cable with the smaller ground was still being used. Common practice was to wrap the ground back along the cable sheath and secure with the clamp of the metal box.
Al cable was also being used for small branch circuits, I passed on that.
Coastal South Carolina
Old 05-08-2011, 07:49 AM   #4
Rewards Points: 1,192
Joe Tedesco would know!
bobelectric is offline   Reply With Quote
Old 05-08-2011, 09:28 AM   #5
Rewards Points: 320
Ahhh the wrapping of the ground. I've heard it called the Boston back wrap but I'm not sure where it originated.
teamo is offline   Reply With Quote
Old 05-08-2011, 09:36 AM   #6
A "Handy Husband"
rjniles's Avatar
Brings back memories but that is what it was called:
http://www.contractortalk.com/f32/bo...ck-wrap-16273/
Don't replay to the thread on ContractorTalk - it is old.
ground - up or down - new code? Potomac101 Electrical 25 03-07-2008 09:45 AM
Conduit, above ground, code question davewest Electrical 6 02-27-2008 03:55 PM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
