Code Compliance - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 09:17 PM   #1
Code compliance
Just want to make sure I have this right.
1 - First square on the top is the main disconnect.
2 - Rectangle right below it is the main panel
(a) same neutral/ground bus bar
(b) bonding strap connected to neutral/ground bus bar
3 - rectangle below the main panel is a subpanel
(a) this subpanel will only feed a 240v receptacle
(b) for that reason, there's no need to use a neutral wire
4 - rectangle on the right of the main panel is another subpanel
(a) this subpanel will feed both 120/240v receptacles
(b) the square on top of this subpanel is a 120v receptacle
(c) the square to the right side is a 240v receptacle
Do I have everything correct, including wire colors?
RichardPryor is offline   Reply With Quote
Old 04-17-2010, 09:40 PM   #2
joed's Avatar
Rewards Points: 11,582
2. Neutral and ground must be separate. Only place you bond them is at the main disco. You must use 4 wire feed to panel and treat as sub panel.
3. Why even bother with sub panel here? If you need a disconnect at the device install disconnect instead of a sub panel.
Old 04-17-2010, 10:12 PM   #3
Thanks, did not know that.
Basically that subpanel is already in place. It just has 2 20amp circuit breakers for a pair of A/C's. The person who installed the A/C's installed this subpanel, but I want it to be code compliant, which ATM is not.
Do I need a neutral wire for this subpanel?
Old 04-18-2010, 10:51 AM   #4
joed's Avatar
I don't know if a neutral is required. I do know that you can't bond the neutral and ground together.
Old 04-18-2010, 11:52 AM   #5
1 - Main disconnect (same neutral/ground bus bar)
2 - Sub-panel
3 - Sub-panel that will only feed 240v equipment
^^Do I need to have a neutral wire feeding this sub-panel?^^
4 - Sub-panel that will feed both 120/240v equipment
^^Rectangle on top of box #4 is a 120v receptacle (no red wire)^^
^^Rectangle on the right side of box #4 is a 240v receptacle (no neutral)^^
Do I have this right? Thank you.
Old 04-18-2010, 04:00 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
A neutral is not required with a stright 240 volt subpanel.
I hope things work out for you!
curbless shower disaster- code compliance?? ck99 Flooring 7 08-31-2011 12:21 AM
need some help on code compliance nap Plumbing 6 02-19-2010 11:39 AM
Code compliance question: plug-in UPS inline with circuit ScottR Electrical 20 06-03-2009 05:26 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 08:52 AM
New Furnace, Code Compliance? theatretch85 Electrical 16 12-23-2008 10:31 PM
