Code Acceptable Cable Routing - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 11:29 AM   #1
code acceptable cable routing
Question for an electrician pls...
I'm remodeling my kitchen and need to run some new circuits.
My panel is in the garage(attached) on the wall OPPOSITE the house.
All the cabling runs currently into the house in a single pathway in the ceiling between the first and second floors.
My 'plan' is to run the new cables across the top of the sheetrock on the
garage ceiling(just as the original wiring is run) but since i can't get it through the same path as the original, I want to
- cut a hole in the sheetrock on the house side of the attached garage wall where it meets the ceiling
- run the cables BEHIND the truss that is right next to the house (about a 2 inch gap there
- run the new cables into that hole in the top of the sheetrock(btw, it's a 10 ft ceiling)
- then down the inside(middle) of that wall, through the floor plate in the basement and then branch out from there.
is this acceptable routing per the NEC? (I looked but couldn't find anything specific enough.
the only place the wiring will be exposed is for about 3 or 4 inches right at the top of the wall where there is already a gap between the wall anc ceiling sheetrock, before it enters my 'planned' hole in the top of the sheetrock for the wall
Thx in advance
tmorriss is offline   Reply With Quote
Old 03-10-2011, 01:10 PM   #2
joed's Avatar
Rewards Points: 13,332
I don't see any problems with your plan. NEC will only tell what you can't do or what you must do. They could never list all the things you can do.
Old 03-10-2011, 02:01 PM   #3
iminaquagmire's Avatar
Rewards Points: 338
It sounds like you want to come out of a hole in the ceiling and go into a hole in the wall bypassing the top plate of the wall. If so, that would not be acceptable. If the cables are continuously in the ceiling wall and exit only into approves boxes, then yes, that sounds fine. If you need to bypass the top plate, you'll need to protect the cables with conduit. As long as the conduit is 24 inches or less, you do not need to derate.
iminaquagmire is offline   Reply With Quote
Old 03-10-2011, 03:06 PM   #4
OK,
Conduit? DOes it matter what type? (hard or flexible)
Does it have to be one piece of conduit per cable, or can I put multiple cables in?
I'll only need to cover them about 3 inches.
Thx again
Old 03-10-2011, 07:16 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Don't forget, you'll have to repair the wall between the garage & house to maintain it's fire rating.
Kyle
Old 03-10-2011, 07:34 PM   #6
Scared Electrician
Saturday Cowboy's Avatar
why don't you remove a drywall patch so that you can drill the top plate and do it right?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-10-2011, 07:40 PM   #7
joed's Avatar
I missed the part about running the cable into the sheetrock hole. If you have "a hole in the sheetrock on the house side of the attached garage wall where it meets the ceiling" just drill the top plate and come down through it.
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 04:31 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 11:00 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
