Coaxial Splitting Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2008, 06:57 PM   #1
jelly's Avatar
Rewards Points: 330
coaxial splitting question
Currently my fiber optic feed comes into my basement and directly into a splitter. Then....
1) One line goes directly into my attic into another splitter which feeds four bedrooms. (all untested so far, new work)
2) 2nd line goes to the first floor tv area.
3) 3rd line goes into the den
4) goes to the wireless modem
How much of an upgrade would it be to replace the splitter (in line 1) with a female/female adapter, run up to the attic, then put a splitter and branch down into all the rooms?
jelly is offline   Reply With Quote
Old 05-26-2008, 07:19 PM   #2
Res Ipsa Loquitur
How much in work or supplies? Do you know how to terminate coaxial cable? The most direct (least split) connection should be to the modem, the rest can be split as necessary. Right now it appears you have a modified home run connection with a 4-way splitter. Why would you want to take this away? If any lines cause problems they can be isolated from the basement.
Are you expecting to gain anything by the change?
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 05-26-2008, 08:33 PM   #3
jelly's Avatar
Rewards Points: 330
Right now i have a splitter branched from another splitter which I've read in this forum is a not a good idea.
It is easy to run the cable now as all the walls are open. Of course $$$ is a factor but the last time I checked, 100ft of cable was under $25.
Old 05-27-2008, 05:37 PM   #4
Res Ipsa Loquitur
My .02c. Not usually but I would check my tv reception first to see if there was any gain with the change. Home runs are usually the better way to go especially with finding a bad cable etc. I think it depends how much the signal will be reduced is the factor. I do know the computer connection should be the cleanest signal of all (read initial split from the main cable) and the tv connections later. You may or may not see a change and then wonder if the cost was worth it.
Old 05-27-2008, 06:15 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Not sure exactly how you have split things but I would think either 2 4 way splitters or a 2 and a 3 and 4 way splitter.
the first way would cause about a 16dB loss and the second way would be about an 18 dB loss to the upstairs tv's.
I would suggest a 2 way when you first enter. One side for the TV system and the other for the internet. Then, on the TV side, add a 6 way splitter so you can feed each tv from this point. That would be about a 14dB loss.
Obviously the less loss, the better. With this amount of loss though, you may find a need for an amplifier. The amp should go right after the very first splitter (the 2 way that splits TV from internet)..
If you use a splitter with extra ports, you should install a loaded termination cap on each unused port.
Old 05-28-2008, 06:15 AM   #6
When is fishing season?
CowboyAndy's Avatar
The more times a signal is split, the more the loss. I learned this the hard way.
Try and keep your modem (as mentioned) a home run, and also think about possibly an amplifier for the longest runs...
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 05-28-2008, 08:54 PM   #7
jelly's Avatar
Rewards Points: 330
Thanks for al the tips guys. nap, I see how easily the dB loss can grow, i will consider....
Old 05-28-2008, 09:54 PM   #8
Rewards Points: 6,652
I did not know that Coaxial can be Fiber. That is a new one that there are actually TV sets that can have a Fiber connection. As for the original question, call your CATV company, and tell them that you are having problems getting a good signal in the house, and set up a service call.
When the tEch gets there, be kind, offer them to where the problem "may" be, and then when done, compliment the hell out of them, and slip in the words "btw, do you happen to have a spare splitter in case I have problems later on, and do not need to call to fix the problem?" If they are cool, they will leave one with you, or even attach it with a small piece of wire where the other one is.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
