Coaxial Connector Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2012, 04:48 PM   #1
coaxial connector help!
Hello,
I recently bought a new plastic coaxial connector to attach on the end of my ariel cable which is fully prepped for the connector to go on..problem is,the coaxial connector I bought has a tiny screw insde the metal tube bit,which essentially, prevents the wire from the cable entering the connector pin..I don't know if it needs to be unscrewed which I've tried and can't get out..also on the back of the packet it says 'Terminate coaxial cables'..which I assume means something bad..can anyone lend a hand?
giodiy is offline   Reply With Quote
Old 09-07-2012, 10:08 AM   #2
Licensed electrician
Rewards Points: 1,018
Coax connectors should be made of metal. I have never seen or heard of a plastic coax connector.
giodiy (09-07-2012)
Old 09-07-2012, 02:22 PM   #3
Rewards Points: 322
Sounds like you may have bought a coax terminator instead of a connector?
tribe_fan is offline   Reply With Quote
The Following User Says Thank You to tribe_fan For This Useful Post:
giodiy (09-07-2012)
Old 09-07-2012, 02:56 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,856
With only one very unusual exception* the word "terminate" used with respect to cables means "to install a connector on the end" or "attaching it to something". Terminating a coax cable means putting a connector on it.
*Some early data networks using multi-point coax wiring required a controlled-impedance termination at the end of dead-end cables. That's probably the kind of terminator you're referring to. But they're still not usually plastic.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
giodiy (09-07-2012)
Old 09-07-2012, 05:33 PM   #5
hmmm
I've never seen a plastic connector and I've been in cable for 12 years. However when we refer to "terminating" a line that means putting a connector that has a 75ohm resistor inside it
combs&co is offline   Reply With Quote
The Following User Says Thank You to combs&co For This Useful Post:
giodiy (09-07-2012)
Old 09-07-2012, 05:50 PM   #6
This makes sense to now. The plastic connector bits are flimsy so I'm switching to the proper metal ones..thanks for your advice
Coaxial cord Bob1145 Appliances 2 08-10-2012 09:57 PM
Pre-wired coaxial cable mapping & digital antenna set up BadHand Electrical 6 10-30-2011 10:37 PM
Coaxial Cable Wiring Help psubaron Electrical 26 08-08-2011 01:33 PM
Coaxial Cable blew tv, computer etc... ozflow Electrical 4 10-13-2008 08:06 PM
New coaxial outlet location shimkc Home Theater 1 01-03-2008 10:55 PM
