Old 10-13-2008, 03:06 PM   #1
Unhappy
Coaxial Cable blew tv, computer etc...
hi there,
So i moved into a new apartment which is actually a loft in the top floor of the house.
My entertainment set-up is common with a tv being connected to my playstation.
Everything was fine with the tv except when I tried to connect my playstation/computer/dvd player using the red, white and yellow cable the playstation and what sounded like a light bulb in the televsion blew with sparks coming from the red, yellow and white connectors where I tried to plug them into the television.
I thought it could be my equipment but the same thing has happened with a replaced tv, different red, white and yellow cables, surge protectors and my computer (now in the shop) being connected.
The electrician has said the outlets are fine. The cable company has told me that the line outside is grounded and that the cable holds no charge.
My landlord is stating that it's my equipments fault which would be believable if it hadn't happened 4 times.
Every time this happens it's only when the coaxial cable is connected. Everything works fine without it. I was also staying in another room of the house for a month with the exact same set-up minus the coaxial cable with no problems.
HELP!!!!!
ozflow is offline   Reply With Quote
Old 10-13-2008, 03:19 PM   #2
Test the voltage in the cable.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-13-2008, 03:20 PM   #3
Sounds like you need someone who knows how to use a "multi-meter" to come and see exactly what is going on.
Under usual circumstances, this should not happen. But anything can happen which could place a "stray voltage" on a wire.
Billy_Bob is offline   Reply With Quote
Old 10-13-2008, 06:00 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
If the ground is not good at the house, bad neutral, or down the line, the CATV company should be able to see high volt's on their line at the house, or at the pole.
Old 10-13-2008, 08:06 PM   #5
Get an electrician to check this out, its probably a loose neutral/poor gnd.
rgsgww is offline   Reply With Quote
Tags
blew, coaxial, computer, playstation, surge
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 09:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
Coaxial cable problem seaox67 Home Theater 1 04-07-2007 11:49 AM
