COAX, Inspected? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 04:56 PM   #1
Rewards Points: 101
COAX, inspected?
do I need to have my coax cable ran before my inpsection? thanks, 1
electrical rough-in/service inspection (forgot that part)
1dumbquestion is offline   Reply With Quote
Old 01-09-2012, 05:14 PM   #2
I suppose it "could" depending on your local code...but it's very doubtful. Phone, Ethernet, Television, Sound have no inspection requirements where I am.
lowvolter is offline   Reply With Quote
Old 01-09-2012, 06:07 PM   #3
Licensed electrician
That is covered on the rough-in inspections where I am.
Old 01-10-2012, 12:35 AM   #4
Rewards Points: 240
That will depend on your area. Where I am, they don't care what you do with low voltage as long as you don't run it into the same box or conduit as line voltage.
fa_f3_20 is offline   Reply With Quote
Old 01-10-2012, 08:29 AM   #5
Rewards Points: 6,652
Here coax is considered Low-voltage and is not an inspection item. Reason being, like Telco, networking, antenna, catv, speakers, video camera systems, alarm wiring, they are considered retro items. Only big thing that is inspected is the grounding systems, which has to follow the latest code for our area, which is the 2008 NEC.
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
How to run new cable to outside? hoggin03 Carpentry 2 08-25-2010 10:29 AM
Time limit for getting work inspected? tigereye Electrical 8 12-22-2009 03:56 AM
Tips on Running Coax handy man88 Electrical 2 08-29-2008 01:07 PM
Coax cable removal or disconnect RobbC2 Electrical 3 04-14-2007 08:21 PM
