Old 01-02-2011, 09:07 PM   #1
Coax Ground Wire Fried
On inspection of why my cable box and lcd tv hdmi input fried, I found the green ground wire on my cable connector outside was severed at both the connector and the inside wall ground post. How could this have happend? Both the connector and the ends of the wires were melted and black, effectively leaving me with no ground on the shared coax line throughout my home.
Phish568 is offline   Reply With Quote
Old 01-02-2011, 09:15 PM   #2
nap
You talking to me?
nap's Avatar
sounds like there was a lot of current flowing across your grounds. Without some investigation, there is no way to determine if it was from some electrical short or an induced current, a combination of both and maybe a poor connection concerning the green ground wire or maybe even a lightning strike.
If you have an above ground service, I would go to the pole you are fed from to check the ground wire there as well. If it was lightning, it may have caused more problems, like maybe somebody's cable box or lcd tv hdmi input.
Old 01-02-2011, 09:28 PM   #3
I live in Sacramento and we rarely get lightning. What we do get is the electric company digging like the movie "holes" all over the neighborhood to fix underground electric cables. I had them in my backyard last month digging a 10'x10' trench to make a repair and the sub electric cable runs right below my Comcast coax...
Had electrical contractors out recently to add to service and upgrade and there is small chance theres an issue with the service. Might have been a poor ground connection though. All incidents with stb failure and burnt hdmi's were the direct result of comcast outages and electrical outages in our area.
Old 01-02-2011, 10:19 PM   #4
Some where some time a large amount of current has used the coax
ground wire to return to ground.
Now normally the bulk of the current should follow the mains
earth to ground.
Why has it not ?
Possibly at the time the mains earth was faulty, or non
existant, so the current took the only other path it could find.
CHECK AND DOUBLE CHECK YOUR MAINS EARTH !!!
If you have any doubts get the electric company to check the earth,
and the neutral strap.
dmxtothemax is offline   Reply With Quote
Old 01-02-2011, 10:38 PM   #5
nap
You talking to me?
nap's Avatar
absolutely, especially given there was recent electrical work done at your home.
That still doesn't explain why the high current on the ground though but it might help to explain the burned conductor.
Old 01-02-2011, 10:56 PM   #6
joed's Avatar
Actually if your mains earth is carrying current you have another problem. It should only be carrying current if there is a fault.
However if the workers somehow cut your neutral then the ground wire would attempt to carry all that current.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-03-2011, 11:04 AM   #7
On numerous threads I have suggested daisy chaining a long wire from one piece of video or audio equipment to the next and connecting the far end to a known ground (earthing). Damage to your own equipment from cable company problems will be greatly reduced if this long wire includes a "stop" right on the coax shell of the first piece of your equipment that connects to cable company lines.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 03:29 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
ground wire debd Electrical 7 04-19-2010 08:05 PM
Panel ground and wire size tns1 Electrical 25 09-18-2009 03:53 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
