Clothing Dryer - Not Getting The Right Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 10:07 AM   #1
Clothing Dryer - Not Getting the Right Voltage
Hi,
Our family was recently displaced by Hurricane Sandy, and once the power came back we began doing some laundry. The dryer was working but not producing any heat. The breaker was not tripped, but i reset it a few times in an effort to fix the problem. Unfortunately that did not work so I had a tech come in an he said it was an electrical problem (after paying him 70 bucks for 5 minutes of work), not an issue with the dryer. Do you think the breaker is bad and needs to be replaced? Any other ideas? I'm handy and trying to save some money...
Thanks,
Dave
myles3030 is offline   Reply With Quote
Old 11-12-2012, 10:15 AM   #2
Rewards Points: 12,878
Power may be back on but you may be only getting 110 volts to the dryer.
Need a volt ohm meter to check it.
Old 11-12-2012, 10:24 AM   #3
Right, the appliance guy said we were not getting right amount of juice to the dryer. So what causes that?
Old 11-12-2012, 11:50 AM   #4
Go buy a volt ohm meter so the guys here can make some suggestion on how to test it or call the power company to come check out there side of it.
If it's a dropped nutral on there side it can distroy anything plugged in to an outlet.
Old 11-12-2012, 11:55 AM   #5
joed's Avatar
Rewards Points: 11,602
You probab0ly only have power to one of the hot lines feeding your house. It could be you whole neighbourhood or just the drop line to your house.
Old 11-12-2012, 12:41 PM   #6
Rewards Points: 1,418
Are there other receptacles or lights here and there that are dead?
Using an incandescent light are there other receptacles that cause it to light up dimly?
Old 11-12-2012, 01:15 PM   #7
Rewards Points: 6,652
Depending on how bad the storm damage was and still is in your area, one leg is still out. File a ticket with your Power Company.
Tags
dryer
open neutral on dryer...dryer won't work inspectorman Electrical 32 02-20-2012 03:16 AM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 07:18 PM
190 185 voltage ? PIGEONS Electrical 10 12-21-2010 12:45 PM
how to avoid condensation in exterior wall when enclosing washer/dryer pemn Remodeling 6 12-01-2010 03:35 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
