Clothes Dryer Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 09:19 AM   #1
Clothes dryer wiring question
Hello,
I have an older Sears (Amana) dryer that I would like to install. Of course, Sears no longer supplies the installation manual.
The wire/plug for the dryer has three wires that screw onto the dryer itself, the other end is a plug.
What kind of wire should I use to go from the panel to the appliance?
Should I supply 220 volts? Would I use a ganged pair of 30amp breakers?
Thank you!
nelsonC is offline   Reply With Quote
Old 06-18-2010, 09:28 AM   #2
I=E/R
a7ecorsair's Avatar
The shape of the plug will give you a clue. Look and see if it says 30A somewhere on it. The plug design determines what it can be plugged into and the manufacture's plate on the dryer should agree.
a7ecorsair is offline   Reply With Quote
Old 06-18-2010, 09:34 AM   #3
the pigtail has three wires which are supposed to be screwed onto the machine, and the plug end has three prongs.
are one of these ground or are one of these neutral?
Old 06-18-2010, 10:08 AM   #4
I=E/R
a7ecorsair's Avatar
The plug, are there 2 prongs at a angle and one prong that is an "L"?
What is on the manufactures plate, does it say 120/240V?
NEC used to allow the ground to be the neutral for the 120 operation of the control but now the neutral and ground have to be separate and use a 4 prong plug.
If there are just three wires the two angled ones are 240 and the L is ground.
Old 06-18-2010, 10:10 AM   #5
thanks. actually, I'm thinking now that I should just upgrade this to a 4-wire, since it seems as simple as disconnecting the ground strap from the dryer and grounding to the frame. so the middle terminal becomes neutral, the outer lugs are hot, and ground is grounded. I think I've got this straight...
Old 06-18-2010, 10:20 AM   #6
I=E/R
a7ecorsair's Avatar
Here's a couple pictures.
Old 06-18-2010, 10:34 AM   #7
that is super-helpful, corsair. thank you very much
Basement wiring question kupalino Electrical 8 11-14-2009 10:25 AM
Wiring Question.... RJBrown Electrical 5 04-26-2009 11:56 PM
Wiring Question bahaisamurai Electrical 3 02-22-2009 12:06 PM
Hair dryer question Ultrarunner2017 Electrical 27 02-03-2009 10:49 AM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 12:37 PM
