Closet Wiring/wires - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 10:57 PM   #1
Rewards Points: 528
closet wiring/wires
In a side by side closet is it required that each have seperate switch or can they be together ?
Also what is the max # or wires allowed in a ceiling light box with 12/2 wire ?
hidden1 is offline   Reply With Quote
Old 10-24-2013, 12:18 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is no requirement for switches in closets.
Without knowing the cubic inches of the box, nobody here could tell you.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Philly Master (10-24-2013), plummen (10-24-2013)
Old 10-24-2013, 02:52 PM   #3
Licensed electrician
Rewards Points: 1,268
The dimensions of the closet may prohibit or severely limit any lighting. Check Article 410 to see the exclusionary zones and types of lighting choices.
Old 10-24-2013, 06:32 PM   #4
Rewards Points: 528
I have 2 fairly large closets you can walk in a tad,both have lights and one switch to both.
was looking to give them individual switches.The ceiling box is the most basic metal octagon shaped box is nailed to side of 2 by 6 ...
Old 10-24-2013, 06:38 PM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by hidden1 View Post
I have 2 fairly large (step in) closets, both have lights and one switch to both... was looking to give them individual switches.
The ceiling box...
If you have access from the attic then it shouldn't be hard to do.
Have fun.
Old 10-24-2013, 07:28 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Are you sure its fed by 12/2? Thats serious overkill for residential lighting.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 10-24-2013, 10:55 PM   #7
Rewards Points: 528
Will be easy because both lights already direct to switch box..just as singe switch.
What is the max on wires..for box../on either one.. my garage has 12/2.
Bedroom Closet Organizing trixie2396 Interior Decorating 10 09-19-2013 07:14 AM
Additional fan in closet Tankeray General DIY Discussions 11 06-04-2013 06:05 PM
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 01:14 AM
Laundry closet decision LClark Remodeling 2 06-26-2011 07:19 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
