Closet Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 06:40 PM   #1
closet lighting
I have an existing light that is a pull chain type. I would like to install a switch in the closet and use that to control the light. How do I do that conversion.
thanks,
Charles
toothcm is offline   Reply With Quote
Old 07-27-2010, 06:58 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Take a cable from the light location to the switch location.
At the light, connect the black from the power source to the white going to the switch.
Mark this wire with a black marker or tape.
At the switch connect the black and white wire to each side of the switch.
Back at the light connect the black from the switch to the black of the light, and the white from the power source to the white of the light.
Turn the breaker back on and enjoy the siwch!
Old 07-28-2010, 10:17 AM   #3
Rewards Points: 87
Originally Posted by jbfan View Post
...and the white from the power source to the light of the light.
Should this say, "and the white from the power source to the white of the light?"
Tipsy
TipsyMcStagger is offline   Reply With Quote
Old 07-28-2010, 05:00 PM   #4
jbfan's Avatar
Rewards Points: 650
Tipsy
Yep, and I fixed it!
Old 07-28-2010, 05:05 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
The least destructive way is to use wiremold to make your runs. I believe they even make surface mount wire boxes so you could use that for the switch. I did something similar a while back but in my case the switch already existed, and I wanted the light on the outside of the closet, not inside.
Some pics here: http://gal.redsquirrel.me/?level=picture&id=933
Old 07-29-2010, 09:32 AM   #6
gmhammes's Avatar
motion sense light...lol no switch needed!
gmhammes is offline   Reply With Quote
Old 07-29-2010, 09:40 AM   #7
Electrician
Proby's Avatar
Depending on the municipality and rehab codes, you might not even be able to re-install that light fixture.
Proby is offline   Reply With Quote
What are my options as far as lighting a closet? Shrute Electrical 2 03-13-2010 05:49 PM
Linen Closet Lighting stubits Electrical 24 06-19-2009 11:32 PM
simple closet lighting theboss Electrical 8 02-16-2009 08:56 PM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
