Closet Light Went Dead - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2006, 08:57 PM   #1
Rewards Points: 33
I have a walk-in closet with a switched overhead light fixture. It quit working the other day, so I figured the bulb burned out and proceeded to replace the blub. It still didn't work. I tested the voltage across the black and white leads and came up with 16.5VAC. I am pretty certain this should be 110VAC.
Does anyone have any idea what could be wrong?
Thanks,
Larry
kennelm is offline   Reply With Quote
Old 07-23-2006, 09:16 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
How is it switched?
Where did you check the voltage?
What kind of meter did you use?
Old 07-23-2006, 10:15 PM   #3
Rewards Points: 33
Answers
Speedy, It is a single pole switch just inside the closet door. I am using a Micronta digital multimeter that I have used plenty in the past so I am confident it works. I just tested an outlet known to work and it showed 123VAC.
Old 07-23-2006, 10:17 PM   #4
Rewards Points: 33
Oops! One more answer
I forgot to say that I tested the circuit where the light fixture is connected. I removed the wire nuts and put my alligator clips there.
Old 07-23-2006, 10:26 PM   #5
Did you check for a loose connection at the light switch?
redline is offline   Reply With Quote
Old 07-23-2006, 10:28 PM   #6
Rewards Points: 33
Loose COnnection
No, I didn't check for that....
Old 07-23-2006, 11:06 PM   #7
The reason I ask about the meter is digital multi-meters (DMM's) are famous for giving phantom voltage readings. I highly doubt the 16v you were reading was actually voltage. I bet the circuit is dead and you just need to find the reason.
Bad connection?
Tripped breaker?
Bad backstabbed receptacle?
Bad switch?
Bad connection at the switch?
Etc..........
Old 07-24-2006, 11:09 AM   #8
Rewards Points: 33
I checked the breaker already. I suspect it might be the switch. Either a loose connection or a just a faulty switch.
I will reply later to let you know what I find with the switch.
Thanks!
Bad connection?
Tripped breaker?
Bad switch?
Etc..........
Old 07-24-2006, 08:51 PM   #9
Rewards Points: 33
That was it. Loose wire at the switch. All is well now.
Thanks for the help guys!
Larry
Old 07-25-2006, 07:19 AM   #10
Larry
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
