-   -   Closet Light Went Dead (http://www.diychatroom.com/f18/closet-light-went-dead-3161/)
kennelm 07-23-2006 08:57 PM
I have a walk-in closet with a switched overhead light fixture. It quit working the other day, so I figured the bulb burned out and proceeded to replace the blub. It still didn't work. :huh: I tested the voltage across the black and white leads and came up with 16.5VAC. :huh: I am pretty certain this should be 110VAC.
Does anyone have any idea what could be wrong?
Thanks,
Larry
Speedy Petey 07-23-2006 09:16 PM
How is it switched?
Where did you check the voltage?
What kind of meter did you use?
kennelm 07-23-2006 10:15 PM
Answers
Speedy, It is a single pole switch just inside the closet door. I am using a Micronta digital multimeter that I have used plenty in the past so I am confident it works. I just tested an outlet known to work and it showed 123VAC.
kennelm 07-23-2006 10:17 PM
Oops! One more answer
I forgot to say that I tested the circuit where the light fixture is connected. I removed the wire nuts and put my alligator clips there.
redline 07-23-2006 10:26 PM
Did you check for a loose connection at the light switch?
kennelm 07-23-2006 10:28 PM
Loose COnnection
No, I didn't check for that....
Speedy Petey 07-23-2006 11:06 PM
The reason I ask about the meter is digital multi-meters (DMM's) are famous for giving phantom voltage readings. I highly doubt the 16v you were reading was actually voltage. I bet the circuit is dead and you just need to find the reason.
Bad connection?
Tripped breaker?
Bad backstabbed receptacle?
Bad switch?
Bad connection at the switch?
Etc..........
kennelm 07-24-2006 11:09 AM
I checked the breaker already. I suspect it might be the switch. Either a loose connection or a just a faulty switch.
I will reply later to let you know what I find with the switch.
Thanks!
Bad connection?
Tripped breaker?
Bad switch?
Etc..........
kennelm 07-24-2006 08:51 PM
That was it. Loose wire at the switch. All is well now.
Thanks for the help guys!
Larry
redline 07-25-2006 07:19 AM
Larry
:thumbup:
