Old 04-12-2010, 09:32 AM   #1
Closet Light issue, Need Help mount on slope
Have done plenty of research and realize that closet lighting is tricky due to codes and strict safety guildlines. Correct me if I am wrong, but what I have found is that you can use either of these methods, You can use any light fixtures as long as it has a fluresant (sp) bulb and is enclosed completely. You can also use recessed lights, but the can also has to have a complete enclosure or lense. I have also heard people say LED recessed but those seem to be pricey.
The problem that I am having is that the closet is rougly 6'X3' but that inside it has a kneewall with a slope going straight up to the other side of closet wall. There is only a small area of flat ceiling 6" maybe? Need to figure out the lighting asap. I was considering the recesseds on the slope but I am concerned about the amount of light it will put off because the IC rated cans (which I need because its going in a rafter bay) and the trim that is enclosed have low max. wattage.
So I am now thinking about just putting two fixtureswith flurescant bulbs and globes and I am wondering if they can be mounted on a slope? Can most fixtures be mounted on a slope? Are there some that can and some that can't? Can I go ahead and mount the boxes on the slope for the rough and feel confident that I can find a fixture that can be mounted on a slope? Not looking for anything fancy (it is a closet) Just a basic fixtures with a glass globe. Any input would be greatly apprieciated!!
bfan781 is offline   Reply With Quote
Old 04-12-2010, 09:56 AM   #2
Just call me Andrew
I donlt think there's an issue installing on a slope. For a small closet, you probably do need fluorescent in an enclosed lamp. I don't believe compact fluorescents (CFL) can be used here in an incandescent socket. You should use a lamp that ONLY takes fluorescent bulbs.
Here is the code snippet about closet lights (Dave, if you read this, might want to update the sticky, it is still the 2005 version):
Andrew
secutanudu is offline   Reply With Quote
Old 04-12-2010, 10:47 AM   #3
Hi, I ran into just this problem in a closet and couldn't find anything in the local supply houses that did what I needed. I ended up finding the Leviton 9860-LHG online. Not sure if you have something like that available locally but I found them online and they worked great. Replacement bulbs are going to be a bear to find as I can't get them locally but the lights work great and mounted easily on a slant wall.
Avramel is offline   Reply With Quote
Old 04-12-2010, 10:56 AM   #4
Master Electrician
A luminaire or fixture is what goes on or in the ceiling or wall. A LAMP is what goes into the luminaire. You do not install a lamp that takes a bulb. A bulb IS the lamp.
brric is online now   Reply With Quote
Old 04-12-2010, 11:27 AM   #5
Ok two question, so I shouldn't have a problem installing on a slope? as long as the correct distances are maintained? Can u hang any fixture on a slope?
Having trouble understanding the code. Can anyone explain a little more. Does a recessed with a fluorescent need to be enclosed or only incandescent? Can any recessed take a fluorescent bulb? Will any fixture that has a fluorescent bulb and also enclosed work in this scenario?
What does everyone think will light up my situation the best. I question whether the Recessed installed in slope would not fully light up all the space because it would shine straight from the slope and not illuminate further down. Would a fluorescent fixure that would stick out more be better to light the space below going down towards the kneewall?
Old 04-12-2010, 11:43 AM   #6
Just call me Andrew
My mistake on the terminoligy. I mean...he/she should install a fixture that only accepts a fluorescent lamp.
I'd prefer a non-recessed light if you want the light to spread out more, assuming it wont be a hazard to where you might bump your head. I am not really a fan of recessed lights in general, though.
Andrew
Old 04-12-2010, 02:37 PM   #7
Great thanks for the advice. I think I am leaning towards out putting in the recessed. Seems like the lighting would be limited and not fully luminate it like a fluresent fixture would. I am curious though if a fluresant blub in a recessed needs to be fully enclosed and if any recessed can take that bulb.
Old 04-12-2010, 02:45 PM   #8
Just call me Andrew
I don't think a fluorescent fixture needs to be fully enclosed, but it's probably a good idea if the ceiling is low/slanted.
Andrew
Old 04-12-2010, 05:44 PM   #9
Electrical Contractor
I install under cabinet lights inside closets, mounted over the door.
You can buy them up to 4' and maybe longer if you look hard.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-12-2010, 06:00 PM   #10
It was a dark and stormy
Yoyizit's Avatar
xxxxxxxxxxxxxxxxx
Old 04-12-2010, 07:32 PM   #11
Master Electrician
Originally Posted by Yoyizit View Post
I think you'll be safe in almost any case. Check out these temps
http://www.tcforensic.com.au/docs/article10.html
Do you ever post anything that makes sense?
I have always wanted to know the ignition point of a cigarette unventilated though :D
andrew79 is offline   Reply With Quote
Old 04-12-2010, 08:24 PM   #12
Yoyizit's Avatar
My bad.
Old 04-12-2010, 08:29 PM   #13
My bad.
I was wondering where you had gotten off too.
Welcome back, I think!
Old 04-12-2010, 09:31 PM   #14
Yoyizit's Avatar
Some of my posts are half-baked, others haven't even seen an oven.
Wiring a closet light ws6 Electrical 2 12-13-2009 07:33 AM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 10:20 AM
Light fixture issue baustin Electrical 4 07-17-2007 05:01 AM
