"Clock Receptacle" - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2006, 12:19 PM   #1
"Clock Receptacle"
Hey, I just installed a 20" lcd panel on the wall of my kitchen and would like to re-locate the receptacle. The current one is already about 4 feet off the floor, but to look clean I need it 2 feet up and over. I know I need to install a new box, but how should I handle it if the current wires won't reach the new destination? I don't want to splice myself into a dangerous situation. Thanks!
toddgfd is offline   Reply With Quote
Old 06-06-2006, 12:33 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
Leave the exsisting box and tap into it, run your new wire to the location you want and install your clock receptacle.
jbfan is online now   Reply With Quote
Old 06-06-2006, 05:31 PM   #3
And you don't want to eliminate a receptacle that's intended for the countertop
Just out of curiosity, can I ask what you mean by "clock" receptacle?
Also a question for another electrician; since this outlet is being tapped from a receptacle that is intended to serve the counter top, would the new one need to be GFI protected?
Sparky Joe is offline   Reply With Quote
Old 06-06-2006, 06:42 PM   #4
Thanks!
Why didn't I think of that? This will be easier than I thought. This wall is in a kitchen, but not near water, so no gfci concerns. I heard the term clock receptacle a while back that referred to the outlet that was installed high on a wall with no other reason than to power a wall clock.
Old 06-06-2006, 07:27 PM   #5
jbfan's Avatar
Rewards Points: 240
I missed the part about being in a kitchen. If that is the case, you can not tap into this circuit. Is there another room on the other side of the wall that you can use a receptacle?
A clock recptacle is a recess box with an outlet inside so the clock plugs in without the cord hanging down the wal.
Old 06-07-2006, 05:00 AM   #6
Check out 210.52 (B) The OP is required to use the SA circuit or run an additioinal 20 amp circuit for this. If the room on the other side of the wall were a living room then to use that circuit would be illegal.
Exactly. What was the original outlet for?
Under the newest code all outlets in the kitchen need to be GFCI protected. The six foot to the sink rule has been changed. What version are they using in your area?
jwhite is offline   Reply With Quote
Old 06-07-2006, 07:00 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
Not really. The two 20a SA circuits is a minimum. A dedicated receptacle behind a permanently mounted TV can be anything you want, once the code minimum is met. If it were a free standing TV you would be correct.
Only receptacles serving the counters require GFI. Not the whole kitchen. This is not a commercial kitchen.
Old 06-07-2006, 04:13 PM   #8
Edit out
