Clicking Noise From Fan Timer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 06:58 PM   #1
Question
Clicking noise from fan timer switch
A Levition LTB60 countdown timer for bathroom fan, about 3 years old, suddenly started making a loud clicking noise. The buttons no longer work to start the fan. The ticking is accompanied by a flashing of the 10M button. It's about 3 clicks per second.
I've turned off the circuit breaker for now.
Any suggestions for diagnosis and repair? Thanks.
msw_1520 is offline   Reply With Quote
Old 02-03-2013, 08:15 PM   #2
chitownken's Avatar
Rewards Points: 510
Don't think those were built to be repaired. Just replace it.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
joecaption (02-03-2013)
Old 02-03-2013, 08:57 PM   #3
Rewards Points: 13,300
Not worth the time to even try and fix.
Old 02-03-2013, 10:30 PM   #4
JuzRick's Avatar
Sounds as a defect within the switch which typically is manufactured with a fuse inside. Hopefully it's just that one switch is defected vs a whole volume of them. I install the motion ones frequently as a design feature to my prospects. They love them! It is better to buy a new one and replace it.
If by chance the new gives the same problem, then the next step would be contacting the manufacturer. Also it's good to make sure there's not a overload on the voltage side(depending how long the device been installed to experiencing the problem). Even perhaps seeing if its grounded accordingly. Things to look at towards troubleshooting.
You would be amazed to know the little problems as improper grounding will cause!
JuzRick is offline   Reply With Quote
Timer Switch Installation Guide iabros Electrical 0 11-16-2012 05:18 AM
Timer switch at end of run tmaher Electrical 3 05-16-2011 07:06 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 01:31 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Timer switch...any ideas how it works? mcvane Electrical 5 09-28-2008 07:32 AM
