-   -   Clicking noise from fan timer switch (http://www.diychatroom.com/f18/clicking-noise-fan-timer-switch-170932/)
msw_1520 02-03-2013 05:58 PM
A Levition LTB60 countdown timer for bathroom fan, about 3 years old, suddenly started making a loud clicking noise. The buttons no longer work to start the fan. The ticking is accompanied by a flashing of the 10M button. It's about 3 clicks per second.
I've turned off the circuit breaker for now.
Any suggestions for diagnosis and repair? Thanks.
chitownken 02-03-2013 07:15 PM
Don't think those were built to be repaired. Just replace it.
joecaption 02-03-2013 07:57 PM
Not worth the time to even try and fix.
JuzRick 02-03-2013 09:30 PM
Sounds as a defect within the switch which typically is manufactured with a fuse inside. Hopefully it's just that one switch is defected vs a whole volume of them. I install the motion ones frequently as a design feature to my prospects. They love them! It is better to buy a new one and replace it.
If by chance the new gives the same problem, then the next step would be contacting the manufacturer. Also it's good to make sure there's not a overload on the voltage side(depending how long the device been installed to experiencing the problem). Even perhaps seeing if its grounded accordingly. Things to look at towards troubleshooting.
You would be amazed to know the little problems as improper grounding will cause!
