Class 2 Circuits (Door Bells & Relays) - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 08:53 PM   #1
Rewards Points: 264
Class 2 circuits (Door bells & relays)
First a little background: The previous owner of my house replaced the typical California wall furnace with a direct vent heater. Think of those log stoves you'd expect to see in a cabin, just burning natural gas instead. Now I'm planning on putting a ceiling fan in the room that has the heater. Since the heater doesn't have any sort of fan, I thought it'd be spiffy to wire up the fan to turn on when the switch was on, or when the thermostat turned the heater on. Thus, in the last few days I started the researching what would be needed to do this.
A little while back, I'd also picked up some 20/2 bell wire so I could properly mount the transformer for my doorbell. The previous owner had buried the transformer in the wall. Running the numbers, I found that the 20/2 wire would work for the fan's relay circuit. However, the wire doesn't have any of the required markings for class two cable. When I went looking for specs on the wire, I was finding that it's apparently 30V 60C rated. Doing some more digging, it seems that most wire sold for doorbells at the big box stores is rated less than 60V.
So my question, aren't doorbell circuits considered class 2 and required to have 150V minimum ratings by NEC 725.179(G)? Or is there an exception that I missed?
a_lost_shadow is offline   Reply With Quote
Old 02-04-2012, 11:31 AM   #2
Rewards Points: 264
bump... anyone?
Old 02-04-2012, 05:06 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
I agree. I've never paid attention to those code provisions before, but I see no reason why a doorbell circuit wouldn't be required to comply with all of the Class 2 or 3 provisions including conductor insulation ratings.
mpoulton is offline   Reply With Quote
Two Circuits Sharing a Neutral brookny Electrical 22 09-12-2011 09:40 PM
Moving multiwire circuits WillK Electrical 5 06-21-2011 07:12 PM
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 04:38 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Adding odd circuits in a bedroom and hood fan oh my! beatle Electrical 3 11-19-2009 07:45 AM
