Clarke SE 160/50 Air Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 04:55 AM   #1
Lightbulb
I have a Clarke SE 160/50 Single Phase Air Compressor, it has never been used, when we came to wire it we found it had a faulty capacitor we then contacted clarke International and were sent a new capacitor, the capacitor arrived and we have installled it. however the compressor runs in reverse which is technically impossible on single phase electricity.
Anybody got a wiring Diagram or have the Answer to this wierd problem.
erg426 is offline   Reply With Quote
Old 04-07-2010, 10:47 AM   #2
Rewards Points: 204
Why is it impossible for a single phase motor to run in two directions? If the motor leads are numbered swap #5 and #8.
If they are color coded swap Black and red.
Old 04-07-2010, 08:38 PM   #3
" Euro " electrician
frenchelectrican's Avatar
If you read the OP's location it from UK so the colours may be diffrent so I will find a correct connection on that motour if they are the same as americiane set up
Merci,Marc
Old 04-08-2010, 03:09 AM   #4
Merci,Marc
Merci Mark, very gratefull for the help.
Old 04-08-2010, 03:11 AM   #5
Thanks, will give it a go.
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
HP - Compressor Failure 2x AndrewF HVAC 43 02-16-2010 04:28 PM
Compressor Replacement Lawrence Coppar HVAC 1 06-30-2009 10:50 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
