Clarification Help - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 10:25 AM   #1
clarification help
i have been all over the forums and didn't want to hijack another thread but i have a few questions that i wanted help with since i want to make sure my wiring/panel is up to code.
1. i have read on here that you can have 15 amp outlets on a 20 amp breaker in the united states (as long as there are at least two). i have an 15 amp outlet in my kitchen that goes to a junction box in the basement and then to a 20 amp breaker. all wire is 12/2 with ground. do i need to change the breaker to 15 amp since that is the only outlet on this circuit or does the junction box act like another outlet so that is ok?
2. i have two outlets in one bedroom that i am 99.9 percent sure are each on their own circuit (14 and 29). would it be smarter to change these to 15 amp breakers or should i put them on 20 amp outlets. what if i put them on 20 amp outlets and something else in the house shares with them?
3. the microwave has a 15 amp outlet in the cabinet above the microwave (wall mounted) and runs straight to a tandem 20 amp breaker. am i correct that i need to change the breaker or outlet?
housemi is offline   Reply With Quote
Old 06-14-2012, 11:21 AM   #2
Code05's Avatar
Rewards Points: 1,104
Is this a standard duplex recepatacle? If so you are fine
What size wire is in the whole circuit? If unsure stay with 15A breakers and receptacles.
Again what size wire feeds the circuit and is this a duplex receptacle?
Code05 is offline   Reply With Quote
Old 06-14-2012, 11:25 AM   #3
Rewards Points: 78
As long as the wire is 12 gauge, you can use 20 amp breakers and 15 amp convenience receptacles. When someone says "single receptacle" they mean this.
Old 06-14-2012, 11:30 AM   #4
Licensed Pro
Expanding on what John said, as long as the receptacles you are referring to are duplex (two receptacles on one strap, which is the most common configuration) you are OK.
Old 06-14-2012, 11:37 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
Not trying to hijack....but....
Since the standard 15A duplex or single outlet will only accept a male plug rated up to 15A, does it really matter if there is only a single outlet on a 20A ckt?
We can put 100 15A duplex outlets on a single 20A line if we want....so why not just one?
On a side note....I use single outlets all the time...especially when I don't want anything else plugged into that outlet....usually it's a UPS on a dedicated ckt....which has it's own breaker....typically a 20A breaker feeding a 15A single outlet.
ddawg16 is online now   Reply With Quote
Old 06-14-2012, 11:45 AM   #6
Code05's Avatar
210.21(B) Receptacles.
(1) Single Receptacle on an Individual Branch Circuit.
A single receptacle installed on an individual branch circuit
shall have an ampere rating not less than that of the branch
circuit.
The Following 2 Users Say Thank You to Code05 For This Useful Post:
ddawg16 (06-14-2012), Evstarr (06-14-2012)
Old 06-14-2012, 12:06 PM   #7
JOATMON
ddawg16's Avatar
circuit.
Hmmmm.......looks like I will need to make some changes to how I design control panels.
Old 06-14-2012, 12:10 PM   #8
Code05's Avatar
Sorry.
Old 06-14-2012, 12:35 PM   #9
see below
Old 06-14-2012, 02:06 PM   #10
these are the type i am referring to. 12/2 with ground runs straight from this receptacle to the 20 amp breaker.
is that ok then?
Old 06-14-2012, 02:27 PM   #11
Code05's Avatar
is that ok then?
Yes, that is a 15 amp duplex receptacle, it is allowed on a 20 amp circuit.
The Following User Says Thank You to Code05 For This Useful Post:
HouseHelper (06-14-2012)
Old 06-14-2012, 04:44 PM   #12
if i understand you correctly i am up to code with only one 15 amp duplex going to straight to a 20 amp breaker?
Old 06-14-2012, 05:00 PM   #13
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
As a side note, you can do the opposite, a dedicated 15amp circuit on a single 20 amp receptacle.
Old 06-14-2012, 05:03 PM   #14
E2 Electrician
Yes... if it were a SINGLE receptacle, it would be a violation, but a duplex receptacle is allowed.
Old 06-14-2012, 06:46 PM   #15
Rewards Points: 6,652
Yes correct.
Sprinkler design question / clarification Hopworks Landscaping & Lawn Care 7 11-20-2011 10:53 PM
Need clarification on different types of wall panel mspiegle Building & Construction 4 07-26-2010 01:23 PM
Clarification on yard outlet vsheetz Electrical 2 12-12-2009 05:09 PM
AFCI - Clarification AndrewF Electrical 12 06-12-2009 11:17 AM
More Clarification on Detached Garage Sub-Panel williamj001 Electrical 18 02-08-2009 01:06 PM
