Clamp Meters - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 12:29 PM   #1
clamp meters
i'm an amateur electrician and i've wired up most of my house at this point so i think i have a decent grasp of the basics. my question is about clamp meters. it seems that the pros use them all the time. what am i missing out on by not having one? i've heard you can detect faulty wiring if you have and and know how to interpret the data properly.
what i'm looking to know is: what kinds of things can a clamp meter tell you that might be helpful in residential wiring? and, how do you interpret the data that it gives you in a useful way?
thanks in advance.
aptpupil is offline   Reply With Quote
Old 02-26-2010, 01:24 PM   #2
Just call me Andrew
Rewards Points: 1,020
Clamp meters measure current (amps).
Andrew
secutanudu is offline   Reply With Quote
Old 02-26-2010, 05:06 PM   #3
ojc
ojc's Avatar
You can turn on all the appliances on one circuit and see what your amp draw is. If you over what ever you deem reasonable for that circuit (check your local code), then you should rethink your scheme.
If the clamp is actually a multimeter, then there are lots of other things you can do with it...find bad wires....trace wires....etc.
ojc
ojc is offline   Reply With Quote
Old 02-26-2010, 06:38 PM   #4
Insert catchy title here
AppleMac*Fit's Avatar
Everything you ever wanted to know about meters and how to use them...
Fluke FREE training
Good stuff, from how to use a multimeter to residential electrical/HVAC troubleshooting and even how to troubleshoot outboard boat engines and electric cars.
AppleMac*Fit is offline   Reply With Quote
Old 02-27-2010, 12:54 PM   #5
Rewards Points: 204
As a homeowner, a clamp meter would be a waste of money. Chances are you would never need it.
Tags
multimeter
one service main two meters danadude1 Electrical 15 02-28-2010 12:17 AM
# of wires per NM Cable clamp joehomeowner Electrical 5 06-15-2009 01:41 PM
GE cl200 kwa meters protechplumbing Electrical 15 09-22-2008 11:10 PM
Clamp Meter Findings jamiedolan Electrical 16 09-08-2008 08:13 PM
Clamp on Amp Tester Help stagger19 Electrical 3 03-07-2007 08:26 PM
