Clamp Meter Findings - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-08-2008, 09:35 AM   #16
Rewards Points: 252
A picture tells a thousand words. Get that panel out. You have nothing to work with keeping it. Forget the sub panel. Install a new 200 amp service with a good brand name panel. ( Square D) would be an excellent choice. That picture seals the deal for me IMO.
Old 09-08-2008, 08:13 PM   #17
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by jamiedolan View Post
Directly about the 100A main, there are lugs for attaching wire, just before the main. So they are always hot. There are currently wires on them, they go to a small box next to the panel, I felt this setup was incorrect (as several here confirmed), and there is nothing hot in the box anymore, I plan to pull it when the meter is off. -- However I am curious, Can anyone tell me what a legitimate / legal use of these lugs would be? Since they are before the 100A main?
jamie
I believe those lugs were put on at sometime to allow the panel to be used as a MLC (sub-panel). I don't know if they are factory installed.
Is it normal to change the upper line at the meter when running new supply line? twilightcall Plumbing 3 08-08-2008 11:10 AM
Moving Water Meter bkeech Plumbing 11 06-15-2008 09:35 PM
What are the rules for a heavy up, between the pole and the meter. TW Lucas Electrical 2 05-10-2008 01:01 PM
Meter ratings Stubbie Electrical 3 04-02-2008 10:12 PM
200A Upgrade - Meter Socket Location Question bjones Electrical 2 11-12-2007 03:03 PM
