Clamp Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 12:04 PM   #1
eastcoastsparky's Avatar
Rewards Points: 150
clamp meter
can you trace circuits with a clamp meter
eastcoastsparky is offline   Reply With Quote
Old 12-02-2012, 12:14 PM   #2
Idiot Emeritus
Rewards Points: 1,492
Only if they're energized, have current flowing, and no other circuit has the same current.
I've used a current clamp to determine which breaker controls a circuit that I want to de-energize without killing anything I want to keep hot.
Rob
micromind is offline   Reply With Quote
Old 12-02-2012, 12:24 PM   #3
Mad Scientist
There's a trick I learned from someone a while back. You connect a lamp or light socket to the circuit you want to trace, and you use a 100W bulb and one of these flasher inserts to make the bulb flash: http://www.cooperindustries.com/cont..._472b_125.html
Your clamp meter will then show that circuit's current draw pulsing at a steady rate, allowing you to identify the correct circuit.
McSteve is offline   Reply With Quote
GB GCM-221 Digital Clamp Meter Greenie Electrical 52 02-04-2012 10:14 AM
clamp meter use? treerat Electrical 3 02-22-2011 10:01 AM
clamp on meter vs killawatt? Red Squirrel Electrical 4 12-22-2010 01:09 AM
New clamp meter question Chevyman30571 Electrical 18 02-21-2010 11:35 PM
Clamp Meter Findings jamiedolan Electrical 16 09-08-2008 08:13 PM
