-   -   clamp meter (http://www.diychatroom.com/f18/clamp-meter-165376/)
eastcoastsparky 12-02-2012 01:04 PM
clamp meter
can you trace circuits with a clamp meter
micromind 12-02-2012 01:14 PM
Only if they're energized, have current flowing, and no other circuit has the same current.
I've used a current clamp to determine which breaker controls a circuit that I want to de-energize without killing anything I want to keep hot.
Rob
McSteve 12-02-2012 01:24 PM
There's a trick I learned from someone a while back. You connect a lamp or light socket to the circuit you want to trace, and you use a 100W bulb and one of these flasher inserts to make the bulb flash: http://www.cooperindustries.com/cont..._472b_125.html
Your clamp meter will then show that circuit's current draw pulsing at a steady rate, allowing you to identify the correct circuit.
