Old 01-08-2013, 10:09 PM   #1
Clamp/Grommet Needed?
Do I need some type of clamp or grommet where this wire goes into this box? This is above a drop ceiling in a basement.
Clamp/Grommet Needed?-dscn2537.jpg   Clamp/Grommet Needed?-dscn2535.jpg
OhioDon is offline   Reply With Quote
Old 01-08-2013, 10:16 PM   #2
Need one of these.
http://www.bing.com/images/search?q=...414E30&first=1
Old 01-08-2013, 10:21 PM   #3
Thanks, did I get the wrong box? Do they make plastic ceiling boxes that don't need that thing?
Old 01-08-2013, 10:23 PM   #4
Licensed electrician
Along with the clamp, the gap around the box needs to be patched to no more than 1/8 inch.
Old 01-08-2013, 10:45 PM   #5
There's lots of other boxes you could have used, some have the clamp built in others have a break away tab that lets you push the wire in but will not let you pull it out.
What is this box for? It does not look like a ceiling fan box if that's what your thinking.
Simplist way to fix that gap is with one of these.
http://www.bing.com/images/search?q=...ture&FORM=IGRE
Old 01-08-2013, 10:49 PM   #6
Licensed Electrician
k_buz's Avatar
I can tell by the mounting bracket in the box that he is installing one of those Commercial Electric LED disk lights.
Location...Location...Location
Old 01-08-2013, 10:53 PM   #7
One of those would look real snappy with that big a gap.
Old 01-09-2013, 07:54 AM   #8
k_buz, you are the WINNER! I got these lights from Polar-Ray so they are not Commercial Electric brand but I believe they are the same light.
The light completely covers the hole so no trim ring needed. Or, is the hole supposed to be patched before the light is attached?
Clamp/Grommet Needed?-dscn2541.jpg
Replacing rooftop deck - permit needed? esk8mw Building & Construction 5 01-27-2012 03:02 AM
Fan size needed for Spray Booth (CFM) Sandy 1150 Painting 0 12-21-2011 08:22 PM
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 02:53 PM
Face nail needed with Bona r851? bakerzdosen Flooring 0 08-01-2011 08:56 AM
Tankless Waterheater recomendations Needed! (please) fremault Plumbing 7 01-27-2008 03:00 PM
