Old 05-16-2012, 07:14 PM   #1
Question
clamp connector for a single wire (ground)
my cable and phone NIDs on the side of the house have grounding that joins in a third box and from there goes inside the house through flex conduit. once it gets in, it goes from the wall, through a PVC elbow, through another foot of flex into a regular steel handy box. there it splices again and from there goes down into the basement, some 80 ft.
the wire coming into the final handy box goes through flex because there is a PVC elbow coming through the wall but on its way out, it is just loose wire (insulated though).
for regular AWG 12 and 14/2 and 3 Romax cabling i use 3/8" clamp connectors to secure cable to the box so it can't be jerked out -- but the opening is too little for just a single AWG 10 wire. i was wondering what the suggested method of clamping this wire on its way out of the box would be since i doubt they make smaller clamp connectors.
thanks
Old 05-16-2012, 10:01 PM   #2
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
The intersystem bonding bars are usually fed with #6 or smaller. #10 seems small.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-16-2012, 10:04 PM   #3
Master Electrician
get yourself a 1/4 20 bolt and nut and bond it to the outside of the box and then pick it up from the ground screw inside the box( assuming your using a metal box).
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-16-2012, 10:56 PM   #4
This style of 3/8 actually clamps it tight. There is another style which doesn't.
Old 05-16-2012, 10:59 PM   #5
kevinp22's Avatar
my antenna grounding block wire is #6 but phone company NID grounding wire is #12. any larger wouldnt fit the connection in the box.
does anyone know what the min required size for phone system grounding/bonding is?
kevinp22 is offline   Reply With Quote
Old 05-16-2012, 11:02 PM   #6
both Verizon and Comcast use #10
Ground Wire Size Question Suprageezer Electrical 12 07-28-2011 04:00 PM
Ground wire ?? Bob1955 Electrical 6 12-25-2010 11:32 PM
Panel ground and wire size tns1 Electrical 25 09-18-2009 03:53 PM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 01:42 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
