Clamp On Amp Tester Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2007, 06:07 PM   #1
Clamp on Amp Tester Help
Hi, I just purchased a GB amp/Volt clamp on tester Model GCM-221.
I tried to measure the amps of a wire, and after clamping the tester around the wire, I was unable to obtain anything. After a quick check in the manual, it states u have to take the reading from either the Hot or the nuetral wire, not both.
Is this a lower end model and thus why I have to clamp on a single wire (Hot or Nuetral) to get an amp reading, or do all of these testers work this way?
Thanks in Advance....
stagger19 is offline   Reply With Quote
Old 03-07-2007, 07:02 PM   #2
jproffer's Avatar
Rewards Points: 716
It's not because it's a lower end model (if it is). It's because +120 and -120 cancel each other out to zero. I don't know of ANY amp-clamp that will read amperage when clamped over both sides of a cable.
jproffer is online now   Reply With Quote
Old 03-07-2007, 07:53 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
If it is just a plug in item you are checking there are adapter available. You plug the adapter into the wall and then plug the item into the adapter. Then you clamp the meter around the loop in the splitter.
Old 03-07-2007, 08:26 PM   #4
Ok thanks for the replies. Its the normal clamp around type.
