Circut Trips When Turning On Light - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 10:35 PM   #1
Circut trips when turning on light
When i turned on a lamp, i heard a popping noise. Then the circut tripped. I turned the circut back on and the light works again. Should i be worried? Is something wrong?
Emx6113 is offline   Reply With Quote
Old 08-24-2011, 11:02 PM   #2
Rewards Points: 734
Yes, be worried. Yes, something is wrong.
Likely whatever caused the short burnt clear. You need to find out the source, whether it be in the house wiring or that of the lamp.
Was it a plug in lamp? If so, leave it unplugged until you check it out. If it's hard wired into the house, keep the breaker off until it's checked.
Just having a breaker trip can happen. You shouldn't hear a popping noise though. That's the concern.
AandPDan is offline   Reply With Quote
Old 08-25-2011, 12:04 AM   #3
Just call me Andrew
Rewards Points: 1,020
Was it the bulb burning out?
Andrew
secutanudu is offline   Reply With Quote
Old 08-25-2011, 10:53 AM   #4
No the bulb. did not burn out. So i should have the lamp and circut checked? What should i have it checked for? Also everything seems to be working now no more tripping.
Old 08-25-2011, 11:02 AM   #5
If i just get a new lamp am i fine
Old 08-25-2011, 11:04 AM   #6
check the recepticle.
mickie is offline   Reply With Quote
Old 08-25-2011, 01:56 PM   #7
recepticle? not sure what that is
Old 08-25-2011, 03:18 PM   #8
sorry, i mean the outlet that the lamp is plugged into
Old 08-25-2011, 05:36 PM   #9
Rewards Points: 734
Have the lamp, I'm assuming it plugs in, checked. Look at the cord, do you see any bare spots? How's the plug? Is it on tight, the wire not cracked from being bent sharply? Does it plug in tightly?
How's the lamp socket? Does it look burnt or loose? Do you see any loose wires?
It sounds like whatever tripped the breaker and popped "cleared" itself. It can make finding it more difficult.
turning switch off trips breaker nhep Electrical 2 02-08-2011 03:36 PM
Circuit trips with 2 light switches sylercider Electrical 3 12-05-2010 11:09 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
Turning pilot light off jmcs23 HVAC 5 06-17-2007 09:38 PM
