Circuits For Dryer, Washer, And Welder - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 08:52 PM   #1
Circuits for dryer, washer, and welder
I have a circuit that I want to make, but I want to be absolutely certain it is safe, and that an electrician would not scowl at the sight of it.
The story is this: I want to move my washer and dryer to another room which currently has an overhead light and nothing else. It will need a fresh circuit. Also, on the way to this room, I want to run a circuit to the garage for my Miller MIG welder. Below is my proposed setup, from start to finish.
One thing to note: the welder would almost never be used when the dryer is also in use. In the off chance it is, it would not be drawing its maximum of 23A, more like 1/2 or even 1/3 of that. Also, it does not use neutral, just pure 230v.
Is this setup "legal"? I am in Ontario.
bossmc is offline   Reply With Quote
Old 08-13-2012, 08:58 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Everything looks on except, the washer has to be on a 20A circuit.
Old 08-13-2012, 09:00 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You need a 20 amp laundry circuit, not a washing machine circuit. I know i'm probably splitting hairs, but it is was it says.
Old 08-13-2012, 10:27 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Might not be required in Canada!
Old 08-13-2012, 10:29 PM   #5
E2 Electrician
True...
Old 08-14-2012, 07:36 AM   #6
Master Electrician
15a is fine. Will the new laundry location have a Washbasin?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-14-2012, 08:24 PM   #7
I was not planning on it. I was going to prop up the washer and have it in a water tray thing (I forget the name) which would then drain into an existing floor drain. (The floor goes uphill to the drain slightly, that's why propping it up would be necessary).
Thanks for the replies.
Old 08-14-2012, 09:42 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,990
Sounds like a wet location. GFCI receptacle?
mpoulton is offline   Reply With Quote
Old 08-14-2012, 09:47 PM   #9
Master Electrician
Washer doesn't have to be gfci protected as long as its not accessable for day to day use. With a washbasin though I believe another plug would need to be added and that one would have to be gfci protected.
Edit: laundry room, washbasin or not, needs the second receptacle.
