Old 01-12-2013, 06:21 PM   #1
Circuit works on one breaker and not another
I have two circuits in my barn. One for lights and the other for outlets. The outlet circuit stopped working suddenly. I checked all outlets and replaced several, all others look good - no loose wires or dirty connections. I then disconnected the black wire from the breaker and connected it to the breaker that controls the lights - the outlet circuit would then work - every outlet would work. So I replaced the outlet circuit breaker and reconnected the black wire. The outlets do not work. I connected the black wire to the new breaker and the lights do not work. If the outlets work on one breaker and not the new breaker - what do I do next?
kbhcdh is offline   Reply With Quote
Old 01-12-2013, 06:34 PM   #2
Licensed Electrician
k_buz's Avatar
I would check the incoming power. Sounds like you lost a leg feeding the barn.
Location...Location...Location
k_buz is online now   Reply With Quote
Old 01-12-2013, 06:45 PM   #3
Thank you for replying. I did notice the connection for one of the lets looked "dirty", I will disconnect it, replace it, and hope that fixes the problem.
