#1 |
Seasoned Noob
Circuit Tracing Tool
So I'm in the middle of a medium kitchen renovation - grantie counters, tile backsplash, new lighting fixtures, new microhood combo to replace the simple vent hood. . . oh and the wife is replacing the pulls on the cabinets
So I dive into the vent hood... need to turn off the power so I look in the breaker box; nothing specific to the hood. So I turn off "kitchen lights" breaker... hood still powered... range breaker? Hood still on... so after switching every bloody breaker off, the range hood is STILL on. Guess I assume it is on a breaker less circuit? Nice huh? I find it difficult to believe that a home builder would do this so I want to buy a circuit tracer.. i mean, its gotta be somewhere! I need suggestions.. nothign too crazy. Maybe < $100... if I find its not on a protected circuit, I'm gonna have to put it on a dedicated, breakered circuit for the new microwave. So what are your thoughts on the tracer to buy? thanks,, RJ |
#2 |
How old is your home / electrical panel? Two circuits may be interconnected and the hood (and other circuits) may be wrongly on two breakers. Before spending the money, I would one by one turn off every breaker in the house and write down what it exactly controls. This may take some time, but will tell you exactly what's going on.
#3 | |
Seasoned Noob
Circuit Tracing ToolQuote:
#4 |
Another possibility that happened in my kitchen remodel.
A 12-3 cable was used to wire the dishwasher/disposal and refrigerator. Either when the drywall or cabinets were hung a screw apparently penetrated the insulation of both hot wires. Both outlets had power with one breaker on and the other off. I corrected the problem by running a new 12-2 to the refrigerator outlet. |
#5 | |
Seasoned Noob
#6 |
Licensed Pro
Are you sure there is not another panel somewhere? Maybe in the kitchen area?
When you turned each breaker off, did you leave it off? Does the hood turn off when you turn off the main breaker? |
#7 | |
Seasoned Noob
There is no other box. |
#8 |
Licensed Pro
Try turning everything off and leaving it off. You may have two breakers interconnected as 47_47 suggested.
#9 |
Seasoned Noob
Circuit Tracing Tool |
#10 | |
Licensed Pro
The more difficult task then becomes "Where is the inter-connection?". Look for a junction box in the attic or basement as that is the most likely location. Have seen this occasionally, and it can be a PITA to located the crossover. |
#11 | |
Seasoned Noob
#12 | |
Licensed Pro
The type of circuit tracer you get for <$100 will not help much in this case. Another thought: Since you said your wife was working from home, did you leave the circuits she was using on the whole time or were they also cycled off? |
#13 |
I would first verify if the hood is on two breakers as HouseHelper suggested. I do not know if the tracing tool will make it easier, but 100.00 for a tool to be used probably only once is your call. I personally buy all the toys that I need, but stay away from the cheapo's, you might as well just send me the money.
#14 | |
Seasoned Noob
and this gives me a reason to buy one... plus they have LEDs on em... we all know from Star Trek that an LED makes anything look cool and 'high tech'
#15 |
By all means buy a tracing tool. When you hook the signal transmitter to the vent-a-hood wiring (or outlet) you should get a signal on two breakers. Then follow HouseHelper's advice. If the vent-a-hood wasn't protected by a breaker it would be obvious. The wiring would be connected directly to the bus in the breaker panel or connected in the meter base. Highly unlikely.
I too like quality tools even though I'm a DIYer. My philosophy has always been if the tool is worth having get it, it's worth the butt chewing the wife dishes out. And my butt has been chewed out many times over the years over tools. |
| Display Modes | |
| Wiring in New Addition? | sandyman720 | Electrical | 6 | 11-27-2011 04:34 PM |
| Problem with circuit breaker. HELP! | spartanic | Electrical | 2 | 10-28-2007 04:09 PM |
| Conflicting Circuit Info!?? | BenBil | Electrical | 9 | 01-15-2007 09:26 AM |
| So lost - electrical requirements please help | lapsis9 | HVAC | 4 | 12-20-2006 09:09 PM |
| Adding new circuit breakers to 100 amp sub panel | DrP | Electrical | 8 | 05-25-2006 11:05 PM |
