Circuit ? Regarding Addition - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 10:18 AM   #1
Rewards Points: 91
circuit ? regarding addition
so i am putting up a 20x40 addition that is 2 rooms and a full bath. i am trying to determine the minimum cicuits out of panel required. i know i need a dedeicated circuit for the bathroom. can i use a circuit for lights and receptacles or is there a formula for number of lights and receptacles for a circiut? outdoor hvac condensor. i think i only need 3 total but maybe not.......
gwilkrrs is offline   Reply With Quote
Old 12-11-2012, 10:56 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
What are the rooms to be used for?
1 circuit for the bathroom receptacles and lights.
1 circuit for each room, and whatever requirmnts the hvac needs.
Thats how I would do it.
jbfan is online now   Reply With Quote
Old 12-11-2012, 11:23 AM   #3
Rewards Points: 91
living room
sitting (reading)room
bathroom
i was wondering if 1 circuit should be to each room or not.
Old 12-11-2012, 11:29 AM   #4
jbfan's Avatar
Rewards Points: 478
You could do both rooms on 1 circuit.
Old 12-11-2012, 11:33 AM   #5
Rewards Points: 91
in all fairness the reading room will likely turn to a bedroom in future if that matters- not now so no arc fault needed
permit is as listed for living, sitting, bath
Old 12-11-2012, 11:43 AM   #6
Not sure of local codes but shouldnt receptacles be 20A + 12Ga, and lighting be 15A + 14Ga?
So then combine all lights on one circuit, all receptacles on another, and HVAC on 3rd dedicated.
jmd87 is offline   Reply With Quote
Old 12-11-2012, 12:36 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Most of this other than the 20 amp ckt for the bath is personal preference.
Mine:
20 amp-- bath
15 amp -- lights in both rooms
15 amp -- receptacles in both rooms
HVAC as required
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
stickboy1375 (12-11-2012)
Old 12-11-2012, 12:48 PM   #8
Rewards Points: 320
Bathroom gfci receptacle(s) 20 amp circuit. Can also be used for bathroom lighting but I prefer not to. The bathroom fan/lights can be on a lighting circuit with other rooms but the other rooms cannot be on the 20 amp bathroom receptacle circuit.
15 amp lighting circuit can be used for all of the lighting in the rooms but I would calculate what the total load will be for all of the lights. 15 or 20 amp circuit for the receptacles in the other rooms. If the load is light as in a bedroom/reading room I prefer to use 15 amps for the receptacles. HVAC condenser will likely be 240 volt and will require a dedicated circuit.
teamo is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Several outlets and lights on a circuit are not functioning, while others are fine. mrdojo Electrical 12 03-26-2012 06:23 PM
Rewiring older house WillK Electrical 12 10-13-2010 01:49 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
