Circuit Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2008, 03:22 PM   #1
Circuit questions
I'm trying to understand how to arrange circuits.
1-Can you put 2 bathrooms on the same circuit? My underdstanding not too
2-Can you put whole second floor lighting(3 bedrooms, 1 hallway, 1 walk in closet) on the same circuit?
3-Is 2 circuit enugh for the outlets for badrooms and halway?
Thanks.
Ismail
ptcamaro is offline   Reply With Quote
Old 04-11-2008, 03:54 PM   #2
Licensed electrician
Rewards Points: 1,502
A 20 amp circuit can serve more than 1 bathroom if only the receptacles are on that circuit.
As far as the lighting circuit, more info is needed. How many fixtures are going to be installed? What size bulbs? Will this circuit be shared with the bedroom receptacles?
Old 04-11-2008, 04:04 PM   #3
Rewards Points: 1,186
You cannot put a new bathroom receptacle onto an existing bathroom receptacle circuit, unless the existing bathroom's receptacle is on it's own dedicated 20a circuit. (Nothing else sharing that circuit, lights, other room receptacles etc...) In which case, all you could add to that existing 20a dedicated bathroom receptacle circuit is other bathroom convenience receptacles only. (No lights, fans, etc...)
You cannot branch off an existing bathroom's 20a circuit if the existing bathroom's 20a circuit also feeds lights or other items within the original bathroom.
If the existing bathroom circuit is less than 20a, or it feeds other receptacles and lights in bedrooms, hallways, livingrooms, etc, then you cannot consider this circuit usualbe within a new bathroom at all.
You can load a 15a lighting circuit up to 1420 watts. A 20a circuit to 1800 watts.
Thanks.
Ismail
Measure the entire sq. ft of all bedrooms & hallway and multiply by 3 watts. If you have less than 600 sq ft x 3 = 1800 watts than a 15a circuit is all you will need, by code minimums. That could include as many receptacles as you would like. But don't expect to be able to run 3 window air conditioners...
LawnGuyLandSparky is online now   Reply With Quote
Old 04-11-2008, 05:15 PM   #4
joed's Avatar
Rewards Points: 12,448
Bedroom lights (and all other bedroom outlets) need to be AFCI unless your region has exempted that part of the code. Therfore usually only bedrooms are grouped together on those circuits.
If your region is on 2008 code many more things need to be AFCI as well.
Old 04-12-2008, 12:44 AM   #5
So looks like I will put each bathroom with their own lighting in separate circuit. 2 other circuit for the outlets ( about 845 sf, 3 bedroom 1 hallway 1 walk in closet) and 1 light circuit( about 7 lights). total of 5 circuit.
And I dont know if NJ wants AFCI.
Old 04-13-2008, 09:07 AM   #6
no more response?
Old 04-13-2008, 09:32 AM   #7
When is fishing season?
CowboyAndy's Avatar
no more response?
c'mon, give everyone a break... it's sunday morning! People are either sleeping in or at church!
Call yout local AJH and ask them if AFCI breakers are required where you are.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-13-2008, 10:47 AM   #8
i forgot, bec. I'm working today. lol.
Old 04-13-2008, 11:37 AM   #9
Rewards Points: 130
Putting one bathroom light on one circuit is overkill. Several rooms would be more like it. I like to keep lights and recepts seperate. So, for an example, I have five rooms with one fixture in each ceiling. All would go on 1 circuit and I still could add more later. It's how you load these lighting circuits that matters. Some ceiling fans have like 5 light sockets in them. Someone could put 5 - 100 watt bulbs in that fan fixture. So just use some common sense and don't use any more breakers than you need.
PS.....Do not use bulbs of higher wattage than what the fixture will allow.
J. V. is online now   Reply With Quote
Old 04-13-2008, 02:59 PM   #10
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Originally Posted by LawnGuyLandSparky View Post
[/i]
Unless you are quoting a local code, this is not true for general purpose circuits in a dwelling unit.
jrclen is offline   Reply With Quote
Old 04-13-2008, 10:37 PM   #11
Actualy, I meant lighting and receptacles in one circuit for each bathroom.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
